Update on broken glow plug.
Old Apr 17, 2006 | 03:48 PM
Das Ungetum's Avatar
Das Ungetum
Smile Update on broken glow plug.
Hello all,
I have not been able to post for a while, so I thought I would share my info with you all.
My 88 7.3 had a "snapped off" glow plug at the rear cylinder. It was broken at the thread so the "business portion" is still in there. We tried left drilling and "easy-out" but there was nothing easy about it.
My mechanic called in a guy who was good at this, and told us to leave it alone as there was damage around it, and the head would most likely need replacement. It does not seem to matter a great deal at this moment. It is still sealed, and since I put a new glow plug controller and 7 new beru's in there she starts quite well.
Any ideas how hard it is to pull those "heads" off? I think I would prefer to replace them both and the gaskets as the CDR was spraying a fair bit of oil in. I am the new third owner so it could have for a while and from what you have all taught me, that causes eccessive heat at the rear cylinders. "I wonder why that glow plug seized?" New CDR works well.
Thanks all!
Mark.
Old Apr 17, 2006 | 05:57 PM
trike1946's Avatar
trike1946
I think the issue is time and weight. I never did it on a diesel, but a lot on gas. I think the book says about 22 hours for the heads. And they are heavy.
Maybe over torque and no anti seize is why it stuck. ????
I'm sure there will be more ideas from others. Good luck with it.
Old Apr 18, 2006 | 11:32 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
They are very heavy and would advise having a lift and chain available to get it lifted. It is quite a job for the novice but do-able. Get a haynes or chiltons diesel engine book before starting and go over it in your mind before starting. While you have the heads off you might as well have the valves/springs checked by a shop.
Old Apr 18, 2006 | 05:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Standard shop guide time to R&R the heads in the truck is 22 hours.
You ca actually pull the engine, replace the head gaskets and reinstall it in the same amount of time. You will also have a much easier time and get a better job doing it out of the truck. The heater and AC on the passenger side of the engine are right in the way, you can not remove a couple of the back bolts because of it. They need to be lifted up and held with pieces of fuel line and come out with the head. Reinstall has to be done the same way. To easy to damage or displace the head gasket while trying to put the head back in place.
Old Apr 18, 2006 | 11:02 PM
Das Ungetum
Thanks Guys!
I was thinking along the lines of Dave and Bigredtruckmi. It would seem that since I was going to all that trouble, why not pull the engine and go through other things as well.
She only has 137,000 km on her, but since I have not had her since new it would be a good idea to do a mini overhaul. The engine starts well for now, and since I'm a little out of pocket buying it, and spending some coin getting it up to speed, I think I will have to wait until the summer.
Either way, I will keep you up to date.
Thanks!
Mark.
Old Apr 19, 2006 | 12:30 AM
bassproguy07's Avatar
bassproguy07
Dave, how hard is it to pull the engine???
renegade_75
Mar 5, 2013 08:44 AM
Twistedwrench
Dec 13, 2012 05:25 PM
maverick1701
28
Mar 18, 2012 12:43 PM
pba369
20
Oct 21, 2011 06:05 PM
dyoungen
Nov 5, 2009 10:05 PM
