Speedo Cable
Old Apr 17, 2006 | 07:17 AM
53Merc's Avatar
53Merc
Question Speedo Cable
Last summer on a trip to Shenandoah Nat'l Park I lost my speedometer. It wrapped around on itself. I can't quite figure out what the problem was but want to avoid this repair and replacement again.
I suspect it got too close to my exhaust pipe and that it may have even touched it but why it twisted back on itself and sanpped??
Can any of you mecahnical scholars provide some advice on avoiding this problem again?
I am planning to tie the speedo cable away form the exhaust but should a speedo cable have particular type of fastener?
LMK
Thanks
GW
Old Apr 17, 2006 | 07:54 AM
GreatNorthWoods's Avatar
GreatNorthWoods
53,
A frozen speedometer head will cause that but if yours is still free then I would suspect either a lack of lubrication or a tight bend in the housing somewhere. It's always a good idea to keep the housing away from excessive heat but I would not think that would cause the cable to break. I don't know if you have a plastic housing or the old metal type. If it's plastic look for signs of melting where it may have layed against the exhaust. That would certainly do it in. I know of no special fasteners required. The main thing is to route the housing away from the driveshaft and exhaust, don't make any sharp turns that might bind the cable in the housing, and use a liberal amount of speedometer lube on the cable...
Vern
Old Apr 18, 2006 | 05:42 PM
53Merc's Avatar
53Merc
Thanks Vern,
That's what I thought... the cable housing was plastic and some of it seemed melted but I suspect the real culprit [besides me I mean ] was a kink or too tight a turn.
Gerry
gravy31
Apr 30, 2011 06:27 PM
getsch58
1983 - 2012 Ranger & B-Series
Nov 29, 2008 05:36 PM
64fordf100292
Sep 16, 2007 07:20 AM
jreilly57
Sep 1, 2006 10:13 PM
Oceanwave
Bronco II
May 20, 2003 08:53 PM
