Speedometer problems
Old Aug 31, 2006 | 10:53 AM
jreilly57's Avatar
jreilly57
I'm having speedo problems on my '48 F-1. It binds and stops working when I back-up. I checked the speedo itself already, and it seems OK, so when the binding happens, I loosen the cable at the speedometer, pull the cable out of the sheath slightly until it moves freely and then re-connect. It then works fine, until, of course, I back-up again!!! The problem seems to be where the cable connects to the transmission under the truck. I bought a new cable which I have yet to install because I was wondering if there is anything else under the truck I need to replace to prevent this from re-occuring. Anyone have any ideas?? Thanks.
Old Aug 31, 2006 | 11:14 AM
barry's Avatar
barry
Your cable may have a fray in the core that moves ok one way and not the other. Pull the core out from the cab end and inspect. If it has any frays or kinks, it's bad. All that's in the tranny is the drive and driven gear. If there was a problem there, you'd see it going forward also. I'm betting on the speedo cable.
Barry
50 F-1
Old Aug 31, 2006 | 11:50 AM
Randy Jack's Avatar
Randy Jack
What Barry said.
The fact that you have to pull the cable out of the sheath to get it to work tells the story. It's frayed.
Old Aug 31, 2006 | 04:03 PM
jreilly57's Avatar
jreilly57
Thank You !!! That's just what I wanted to hear!! I'll install the new cable (and sheath) tonight.
Old Aug 31, 2006 | 05:13 PM
5 Star's Avatar
5 Star
Make sure you don't forget the lube on the new cable.
Old Sep 1, 2006 | 07:16 PM
jreilly57's Avatar
jreilly57
I used powdered graphite as a lube (the guy at the auto parts store said it would be fine). Does that sound OK? It works fine now with the new cable.
Old Sep 1, 2006 | 09:06 PM
48ATOY's Avatar
48ATOY
Make sure that you oil the felt oil port on the back of the speedo
mine locked up an broke the cable
hope this helps
Joe
Old Sep 1, 2006 | 10:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
On the Bonus Built F-1's, the speedo cable makes a hard 90 right above the tranny. Depending how you have the cable routed, it can really wear the cable. When you put in your new one, make all turns as long as possible. Make sure the ferrule at the trans is square and tight.
-- Ross
50trucking
Sep 23, 2014 03:13 PM
tip49
Feb 14, 2013 12:35 PM
PRUSue
Dec 11, 2011 12:06 PM
coopdagook
Jul 31, 2011 05:33 PM
Randyvan
Aug 26, 2003 10:32 AM
