upgrading hubs, why change spindle nut?
Old Apr 16, 2006 | 06:03 PM
95-F250's Avatar
95-F250
1995 F250, 4 wheel drive, one of my auto hubs is broke so I am going to change to Warns. Why do the spindle nuts have to be changed?
With the hub off I see a snap ring on the end and the spindle nut is back a ways, I just don't see why it has to be changed?
Someone enlighten me please. I know there must be a good reason I just am not seeing it.
Old Apr 16, 2006 | 08:19 PM
brown 4x4's Avatar
brown 4x4
I have factory style manual hubs on my 95 F-150, with automatic style spindle nuts. I'm thinking the PO changed out the automatic hubs to factory manuals. I also worked on 96 F-250 with this same setup, only with Warn hubs.
With the automatics, there is only an inner adjusting nut with a c-shaped clip keeping it from backing off. The automatic hub is designed to fit in and work with this type of nut.
I do plan to switch to the double nut style when I repack my bearings which I need to do sometime soon. I think I trust that more. But I've never had a bearing loosen up in the 80K I've had the truck. And who knows how long someone else ran it that way.
Old Apr 16, 2006 | 08:38 PM
dwo's Avatar
dwo
The spindle nut used with this type of automatic lock is too thick and may not allow the new lock to seat fully. I installed Milemarker locks, and there was about 1/32" of interference between the auto nut and the part of the lock that engages the splined shaft. I thought about grinding or machining away part of the meat, but I had already bought the "conversion kit," which are just four nuts and two washers that come on manual locked hubs, so I installed it.
Macs1964F100
Jun 2, 2014 09:56 PM
Infinite Monkeys
May 20, 2013 08:03 PM
78f150L6
Nov 29, 2012 08:51 PM
BruceJeremy
1997 - 2003 F150
Sep 25, 2011 05:17 PM
Victor L
Oct 14, 2010 04:55 PM
