Factory Keypad Code
Old Apr 16, 2006 | 03:38 PM
RedRider3141's Avatar
RedRider3141
Factory Keypad Code
I know it has been asked over and over but... Everybody has a different answer.
Vehicle: used 2004 F150 Lariat S-Crew
Where is the module with the 5 digit code number? I have no 2x3 card, and dealer wants 1 hr labor to read it from the computer.
Some say it is under the passenger dash.
Some say it is behind the rear seats, which apparantly are a pain to remove.
If I have a OBDII Scanner can I read it myself?
Thanks for all the info.
Old Apr 16, 2006 | 04:57 PM
SuperBlue's Avatar
SuperBlue
The factory code you can not change but you can put your own code in, its a black box with a white sticker on it on the drivers side tucked up under the dash.
Cheers!
Old Apr 18, 2006 | 08:31 PM
powerglide's Avatar
powerglide
Behind back seat on drivers side,
Period , end of debate. 2005 SC FX4. I know , I took it out and found it.
Old Apr 18, 2006 | 08:37 PM
superrangerman2002's Avatar
superrangerman2002
Are you sure that it's the same on a super crew truck?
Old Apr 18, 2006 | 09:43 PM
azfordowner's Avatar
azfordowner
Keep in mind that if you do add your own code, it will be erased if your battery dies or runs low. So keep the factory code handy once you know if.
Old Apr 18, 2006 | 11:58 PM
the4by4freek's Avatar
the4by4freek
Ditto on behind the rear seat. Try another dealer.... My local dealer wanted to charge me $80 for the code. I took it to another dealer and they did it for free. It takes 20 seconds to retrieve the code. I watched them do it!
Hunt4jesus
6.4L Power Stroke Diesel
Jan 21, 2014 02:08 PM
92will
Jul 28, 2011 08:28 PM
rebel33382
Sep 15, 2009 08:34 PM
10strokin
Modular V10 (6.8l)
Jul 1, 2008 08:56 PM
dcara
Sep 10, 2007 01:59 PM
