Sorry for the stupide question, but I have the three buttons on the right side of the steering wheel that say; info, reset, and something else. Are they just there for looks??? When I push the nothing happens!! If they are for looks how hard would it be to add the Lariats message center functions?
After further review I do not even have a trip odometer!!!! If I do how do I display it???I have pushed every button I can think of and still can not get the trip odometer to display. Am I missing something?
Thanks guys, but I have checked both!! Sorry for being dense. The owners manual tells me how to use it, but the buttons don't do anything. When I had my 04 Lariat you would hear a beep when it switched menus. I am going to give the dealer a call next week to see if they can help. I can see the total number of miles, but I can not reset one to check total take usage. I am currently doing it the old fashioned way (current miles minus previous fill up miles).
The message center in my '04 FX4 is pretty basic - press the button and the display cycles through three modes - odometer and two trip meters. Press and hold the button while in tripmeter mode and it resets. No sound. FWIW, I had to have my message center replaced because the backlight quit. That involved replacing the entire gauge cluster (which required a special order part ordered and installed while under warranty by my local dealership).
Found the problem!!! I didn't have the "stick" sticking out to toggle through the options (trip and odometer), but I do have the hole in the cluster. I will call the dealer Monday! Thanks for your help!!
Those of you with the FX4 package what is the purpose of the three buttons on the right side of the steering wheel on the dash (Info, Setup, and Reset)?
I called the dealer and they looked at the FX4s on their lot and none had the buttons. SO the "head" truck man is suppose to call me to fill me in!! We shall see.
I just Spoke with the dealer and they are saying it was a factory mistake!!!!! Good one for me!!! Now what can I conect to them?????? How do I find out if they are live?
Thanks,
Keith
i was thinking today that your truck might have started as a larait and ended up a fx4. you should beable to take it apart and test it. i dont know what you would hook up to them though.
