Get shocked when exiting.....???
Old Mar 3, 2008 | 07:41 AM
heymrdj's Avatar
heymrdj
04 Expy, shocked every other day :P. And no khaga, it's not about the vehicle moving. It's the fact that the body of the truck has a static (constant amount) of electron charge built up in the body. You however, by sliding into the seat, cranking, then sliding out, built up a charge that had to go somewhere, so since you had a + of electrons, while your truck body had the same amount, but fewer than you, making it -, the + flowed to the - so that they are =. Also, when you cranked it, it's possible that the electronics charged the grounds, which happen to connect to the body, making the truck body +, your body -, and thus you became the =lizer. Either way, you're getting shocked, it's the nature of the beasts :P.
Old Mar 3, 2008 | 05:33 PM
operator414's Avatar
operator414
I always touch something metal before getting out, like the door jam or the door itself to ground myself, it sucks when it happens because sometimes its a good jolt!
Old Mar 4, 2008 | 09:28 AM
2000Expy's Avatar
2000Expy
Talking
Cloth seats have the same problem. I think you should buy some of those straps and a set of curb-feelers as well.
curbfeeler
static eliminator
anti-static strap
unyalli
Jun 8, 2014 08:52 PM
Corpsman24
Mar 29, 2013 12:22 PM
johnson2007
Feb 10, 2011 11:53 PM
Vernon_04_Expy
Mar 15, 2004 08:39 PM
robthai92
1983 - 2012 Ranger & B-Series
Jan 26, 2004 08:11 AM
