Wiring Problems.....
Old Sep 11, 2002 | 05:14 AM
billpattillo's Avatar
billpattillo
I have a 1971 Ford F100 I am restoring. The wires from the starter cylinoid switch melted when my kids were blowing the horn. The horn didn't work, but the wires started to smoke and melted. The battery cables also get very hot when trying to crank the truck. Any ideas on what my problem might be??? Help
Old Sep 11, 2002 | 10:53 AM
Mil1ion's Avatar
Mil1ion
Starter cable problem:
Bad Ground cable connection.
Horn problem :
Horn wiring in wheel
Horn relay
Bad ground
Btw, It's * Solenoid *
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Sep 11, 2002 | 04:57 PM
krazdndenver's Avatar
krazdndenver
Sounds like a short in the wiring. Since the shielding melted a wire is most likely touching metal now causing the short.
Robert
72 F-100 W/ 86 5.0L W AOD
krazdndenver(No Email Addresses In Posts!)
www.geocities.com/krazdndenver
Old Sep 14, 2002 | 10:02 PM
billpattillo
Where can I find a wiring kit to replace the wires?
Old Sep 14, 2002 | 11:00 PM
Mike W's Avatar
Mike W
I would just cut out the bad wires and splice in new ones. Just be sure to make a good connection. I prefer to solder them.
Old Sep 21, 2002 | 01:53 PM
billpattillo
>them.
I found a new wiring harness @ Dennis Carpenter... installed the harness, now I am back to where I started. We are trying to get the engine to run, adjusting the carb..etc.. But the wire running from the Starting Motor to the Starting Motor Relay and the Ground Battery Cable are getting very hot.... the starter wire started smoking... the harness i installed is doing fine, its not warm at all... What do you think the problem is?
Old Sep 21, 2002 | 05:28 PM
Mil1ion's Avatar
Mil1ion
Too much resistance in the starting circuit.
Clean all the connections and try it again.
If you Still have problems.
Pull the starter,as it's probably gone bad inside the case.
[/font]
Old Sep 21, 2002 | 06:04 PM
jor's Avatar
jor
If it's not a bad connection to the starter, it is likely the starter itself. Buy a lifetime waranteed replacement at Autozone for $50 (plus $15 core charge). Spend another $11 for a purdy red solenoid and you will live happily ever after. I hope you don't have headers. If so, I'll retract the live happily comment.
jor
Old Sep 21, 2002 | 06:35 PM
Amberlyns75's Avatar
Amberlyns75
