Newiest Flash
Old Apr 14, 2006 | 07:58 AM
XxfirmanxX's Avatar
XxfirmanxX
Newiest Flash
Just wondering what the newiest flash was for the 6.0 trucks
Old Apr 14, 2006 | 08:28 AM
kw5413's Avatar
kw5413
It is dependent upon your engine build date.
Old Apr 14, 2006 | 11:00 AM
XxfirmanxX's Avatar
XxfirmanxX
aug of 04 is the build date
Old Apr 14, 2006 | 11:07 AM
kw5413's Avatar
kw5413
Sorry, I am confused. Your profile states an '04 F-250. But, you also state that your build date is Aug of '04...I think only '05 MY was being build in Aug of '04.
If your build date is Aug of '03 then you would have an '04 MY with and '03 engine...pretty confusing I know.
FYI: The '04 MY did not have the '04 engine on the production line until 09/29/2003.
If you do have the '03 engine in your '04...this is the lastest flash that I am aware of:
2003/04 Computer Programming Recall 06E17:
Truck built before 9-29-03 are being recalled to have the computer reprogrammed. The reason for this recall is to correct fuel injection timing during cold operation, EGR valve control, lack of power, check engine light illumination (P02263 or P0299), hard starting and rough running concerns related to Exhaust BackPressure sensor corrosion. Other symptoms not listed in this recall, but which could occur, would be excessive smoke, turbo control and surging at idle or cruise. The new update eliminates the EBP sensor input to the computer. The exhaust backpressure will now be inferred/calculated using other sensor signals. Trucks should be reprogrammed using versions 41.8 or 42.1 or higher.
After this reprogramming, the turck should be test driven, the computer checked for a codes and the codes cleared (even if none are present), the key cycled on for five seconds, then turned off twice, then the engine started and allowed to idle for 5 minutes at operating temperature to allow the computer to relearn the EGR valve closed position value. This is to prevent erronious codes or driveability sysmptoms related to the EGR valve an turbo performance. Broadcast Messages 5452, 5529.
You should notice an increase in turbo cycling closed/whistling at idle and at stops. This is normal, and is to help keep the variable vanes from sticking
Old Apr 14, 2006 | 03:08 PM
Super Steve's Avatar
Super Steve
I just received a recall notice from ford saying I should bring my truck in for this flash asap. I dont have any problems with it other than 12-13 mpg. I do think the disabling of the exhaust back pressure sensor might be good though if I plan on straight piping it.
Old Apr 14, 2006 | 04:00 PM
kw5413's Avatar
kw5413
And your engine build date is?
Old Apr 14, 2006 | 05:26 PM
XxfirmanxX's Avatar
XxfirmanxX
Thanks kw5413 my fault it was a 03 engine and the build date was 04/04 my other truck is aug and its gas but it there a was to see what flash you currantly have.
6ohin25401
Feb 6, 2007 02:41 PM
tastyklair
Paint & Bodywork
Jul 7, 2006 09:46 PM
WWBeast
Apr 26, 2005 07:49 AM
JPage
1983 - 2012 Ranger & B-Series
May 3, 2002 07:06 AM
Flash
Apr 7, 2002 08:51 PM
