master mechanics boggled
Old Apr 13, 2006 | 06:27 PM
strokd's Avatar
strokd
Angry master mechanics boggled
I have a early 1999 7.3 superduty with a banks powerpack along with a six-gun. the problem is the truck is having a intermittent extremely rough idle and occasionally stalls while driving at different speeds. i have changed the cam sensor once with a ebay part (brand new still in package) and it did not fix the problem and the second time bought the part from ford which also did not fix the problem. i have took out the six-gun and the otto-mind chip both and seperatly and the problem did not stop. i have no error codes on the six-gun and the service engine soon light pops up when it wants to but not all the time with the problem. i have changed the oil to try to fix the idle and even switched oil to see about foaming. i have changed the fuel filter and checked for air leaks. took the truck to ford master mechanics and they had no clue after i got codes read the codes are, p1280, p0237, p1690, p0381, p0603, p0470 koer p0476 ford suggested a exhaust back pressure sensor and so i got one and no still no fix! i have no clue now??? maybe a bad injector???? please help
Old Apr 13, 2006 | 06:33 PM
clux's Avatar
clux
have you checked your valve cover wiring harnesses?
Old Apr 13, 2006 | 06:44 PM
strokd's Avatar
strokd
na not yet i guess that is next? so i pull the valve cover and check the wires that go to each injector?
Old Apr 13, 2006 | 07:19 PM
maevans's Avatar
maevans
This may help-http://www.forddoctorsdts.com/articles/article-05-10.php Good luck
Old Apr 13, 2006 | 10:16 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Odd that they saw the P1280 and didn't suggest a new injection control pressure (ICP)sensor. You might also check/replace the o-rings on the injection pressure regulator (IPR) valve.
Old Apr 13, 2006 | 11:03 PM
barebackjake's Avatar
barebackjake
with that code i was thinkin the same thing the ipr goin wacky.
id replace the ipr orings too.
Old Apr 13, 2006 | 11:05 PM
pmasley's Avatar
pmasley
When you replaced the BP sensor, did you clean out the pipe?
Old Apr 14, 2006 | 02:53 PM
strokd's Avatar
strokd
i plan on working on it this weekend and find out what is causing it. at least you guys are heading me in the right direction. ill let you know how it goes. thanks
Old Apr 14, 2006 | 10:55 PM
Duane99's Avatar
Duane99
mine did the same thing and it was the connection to the ICP sensor, slipped a wire beside the pin to tighten up the connection and it hasnt happened since. It had the exact symptoms as you describe
lp92chateau
British Columbia
Nov 19, 2006 02:02 PM
sla3492
Electrical Systems/Wiring
Apr 21, 2006 02:21 PM
dakota joe
Apr 13, 2006 05:43 PM
gordon500kv
Mar 31, 2006 12:01 PM
MudBugn
Mar 30, 2006 11:35 AM
