Adding keyless entry to pwr locks
Old Apr 7, 2006 | 10:14 AM
sla3492's Avatar
sla3492
Smile Adding keyless entry to pwr locks
I'm adding Keyless Entry to my power door locks on my 1992 Ford F250 7.3L DSL. The Installation manual states to find out what type of factory power door lock system is in use. Anyone have a clue....I sure don't. It has different instructions depending on the type you have. 1 example is 3 wire grounded switched signal step door locks. and there are several others.
Old Apr 7, 2006 | 01:51 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
2W7Z 19A361-AA is the Ford kit to add keyless entry and comes with installation manuel. If you are installing after market kit. You might want to return it and purchase the Ford kit. Just a thought.
Ed
Old Apr 7, 2006 | 04:16 PM
Franklin2's Avatar
Franklin2
Ford uses the locks that are like little motors. Both wires come from the lock motor, and none are grounded. To lock, the + is put on one lock motor lead, and the - on the other. To un-lock, the polarity on the two lock motor wires is reversed.
Old Apr 20, 2006 | 08:10 PM
kyhillbilly2's Avatar
kyhillbilly2
Discountfordpart will the kit you mentioned work on an 06 f250 with power locks?
I don't have RKE but do have power locks.
I want to add the ford parts to get this feature ....what do i need to do?
Thanks for any info in advance!
kyhillbilly2
Old Apr 21, 2006 | 10:04 AM
Parts Guy Wyatt
Former Vendor
YES, it will work. I called tech line to make sure. That stated that you will also need two relays YL3Z-19G390-AA
Go to my web page, link on bottom of page and input part numbers and summit order I'll process it for you.
Ed
Old Apr 21, 2006 | 02:21 PM
kyhillbilly2
Talking Thanks
Thank you discountfordpart .....
Look for my order!
Kevin
lp92chateau
British Columbia
Nov 19, 2006 02:02 PM
Texmo
May 4, 2006 12:42 PM
MudBugn
Mar 30, 2006 11:35 AM
FTE Ken
Site Announcements
Jan 18, 2006 10:41 PM
