can i do better?
Old Apr 25, 2006 | 12:26 PM
  #31
1975Ford's Avatar
1975Ford
Originally Posted by northey87
would a cracked exhaust manifold be a reason for bad mpg's? yesterday when i was in the engine i noticed small craks in one of the exhaust manifolds.
Yes a cracked exhaust manifold would throw off the air/fuel ratio in the combustion chambers. Replace the manifold, and torque the exhaust bolts. Do not overtighten.
Old Apr 25, 2006 | 12:59 PM
  #32
northey87's Avatar
northey87
qman, where do you get the acetone? i would like to try it in my truck, also what would be a good amount to try per tank?
Old Apr 26, 2006 | 12:30 PM
  #33
qman's Avatar
qman
I get it at Wal-mart in quart cans for about $4. It's over with the paint and strippers. I also bought a small plastic bucket with 4 oz gradutions on it. The article I mentioned said that 3.5 oz/gal was optimal so I try to put 5 oz in it at every fill up since I always put about 15 gal in. It seems to do something. Some here think it is just cleaning things and doesn't really enhance the burnability of gas. But I don't know how that would be. What would be getting cleaned by acetone that increases the gas mileage, carb, intake, valves...? I don't see how cleaning those things would increase gas mileage.
Old Apr 26, 2006 | 05:48 PM
  #34
northey87's Avatar
northey87
thanks, ill try it.
Old Apr 26, 2006 | 08:51 PM
  #35
northey87's Avatar
northey87
ok, i finally got around to getting a compression test done on it. all eight cylinder averaged about 145psi, the highest was 150psi and the lowest was 140psi. is 145psi high? low? good? bad? or what?
Old Apr 27, 2006 | 05:37 PM
  #36
qman's Avatar
qman
That's great. All my cylinders are between 108 and 120 and most are 1111-114. Someone here told me those were good numbers. I think a good compression range is pretty big with the important thing being that they're all close.
Old Apr 27, 2006 | 09:36 PM
  #37
northey87's Avatar
northey87
thanks, that makes me feel better, cause i thought maybe i did it wrong some how. good that means the engine is still top notch inside. thanks for all the help everyone!
Davidvc1964
Jul 5, 2013 02:59 PM
Rusty Axlerod
Mar 29, 2011 06:20 PM
JohnBoy2
2004 - 2008 F150
27
Sep 19, 2008 05:28 PM
1978fordf250
28
Nov 22, 2006 01:54 PM
DeckedoutF150
2004 - 2008 F150
16
Aug 29, 2006 12:25 PM
