I put an IDM out of a 2000 I bought off fleabay in a friends 1997. They are interchangeable. That was one of the first questions I actually asked when I found this place.
yep i have taken the idm out of my 95 and put in a customers 2002 for test purposes and it worked fine. but that was short term. one guy selling new idms on ebay says the ones he sells will work in any psd to 2003
IDM=Injector Driver Module---it basically sends a high voltage signal to the injectors to fire them. Does some signal checking in a feedback loop to the PCM.
It's like the amplifier in a stereo system that drives the speakers.
Nut
I'm almost 100% positive mine went bad .......droped entire left bank of injectors ...i've taken the valve cover off and ohmed the wiring harnes and the plug for the UVC gasket and all wires are plugged in and ohm ok
only thing left is the IDM
thanks for the response guys
I'll get to go work on it soon and i'll plug it in and pray
