Cab Mount install problem
Old Apr 11, 2006 | 02:45 PM
f100tk77's Avatar
f100tk77
I have a 77 f100 and im currently working on taking the cab mounts off. I started with the rear mounts and was able to get the bolt out but for the life of me i cannot remove the bushing the lower bushing under the frame has the nut that welded to the bushing as far as i can see that runs up threw the top bushing. but i can get either of them off after taking the bolt out. any help would be great thanks...
Old Apr 11, 2006 | 02:51 PM
rmalottwtes30's Avatar
rmalottwtes30
Maybe burn the bushing out?
Old Apr 11, 2006 | 02:53 PM
f100tk77's Avatar
f100tk77
I could try that.. I used an impact hammer,air chiesel, crowbar, and tried to pound it out with a hammer.
Old Apr 11, 2006 | 06:42 PM
old timer 4x4's Avatar
old timer 4x4
try putting the bolt back in about half way, then hit the bolt with a hammer. this should separate the two haves of the bushing. the top and bottom bushings slide into each other and they sieze together. worked for me on all the cab bushings i have had to take apart, just my 2c worth.
Old Apr 11, 2006 | 08:48 PM
f100tk77's Avatar
f100tk77
ok thanks im going to try that tomorrow
Old Apr 11, 2006 | 09:34 PM
Hyperactive460's Avatar
Hyperactive460
try a saw - zall....
Old Apr 11, 2006 | 10:03 PM
f100tk77's Avatar
f100tk77
We gave that a try but the rubber starts to melt making it hard to cut but you also have the metal sleve. We are going to try the hammer approach tomorrow.
brf2
May 6, 2022 07:32 PM
jerryst
Apr 2, 2013 06:31 PM
cujo8
Sep 24, 2011 12:28 AM
andyz77vette
Jul 2, 2011 10:54 AM
Orange1975
May 17, 2007 10:43 PM
