Bad Rings Or Piston
Old Apr 11, 2006 | 11:01 AM
tobyjustin81's Avatar
tobyjustin81
Bad Rings Or Piston
I Have A 2.3 Turbo Out Of A 88 T-bird I Think I Have Bad Rings Because I Checked The Compersion On All 4 Cyl And The Reading Were #1 165 #2 160 #3 160 And #4 75 When I Put Oil In The Cyl The Compersion Came Up To 105 Still Not Enuff And Help For A First Time Builder?
Old Apr 11, 2006 | 11:21 AM
JD717's Avatar
JD717
may not be either one, it COULD be a blown head gasket letting compression leak out giving that low number. if its not, the only way I can think of to tell for sure, is tear it down for a rebuild.
Old Apr 13, 2006 | 08:11 PM
Bart99GT's Avatar
Bart99GT
x2
Usually these motors don't have problems with the rings or pistons unless the motor experienced prolonged detonation.
Old Apr 17, 2006 | 12:29 PM
JD717's Avatar
JD717
Now that I think about it, since this is a TURBO motor, it may well have seen too much boost and head gasket go bye bye.
Old Apr 20, 2006 | 01:16 PM
Old Rob's Avatar
Old Rob
Post
You can also have a valve sealing problem. The best way to determine cylinder condition is with a leak down tester. That will tell you where the leakage is. A poor mans leak down can be done. Remove the two rockers from that cylinder and apply 100+ pounds of air pressure. Listen for where the air is leaking. That will tell you which valve or if it's a headgasket or rings.
brian.hill4
Oct 21, 2012 05:47 PM
ndfollmer
Mar 16, 2009 06:15 PM
4.2 Round Two
3.8 & 4.2L V6
Oct 22, 2005 12:48 AM
caddywhompus
1978 - 1996 Big Bronco
23
Jun 28, 2004 09:32 AM
FTE Ken
Site Announcements
May 17, 2003 10:41 AM
