4R70W swap
4R70W swap
I took a 4R70W from a 2003 F-150 and slapped it into a 1999 E-150. When I plugged in the driveshaft, the transmission was too long. There are two different length tailshafts for the 4R70W. The newer transmission in the older van is the shorter one. I swapped tailshaft housings (added the longer housing) and everything matches up. The problem is that the tailshaft is about two inches shorter, however, it is engaged with the driveshaft. Am I going to have any troubles running this transmission?
88gtblack
06-05-2013 06:18 PM
jmalecek
01-12-2004 10:04 PM
