1996 F150 Restoration
i am not taking the motor out or the transmission, i just had the trand out and replaced some engine gaskets (rear main, oil pan) now the bed is off and i am working ont he rear suspension, when i would turn corners before, you could hear a popping sound like the weight of the truck shifting so i have to find that problem. i am not takign the cab off or the engine out, and the truck rode good, i just wanted to know while i have the bed off if there are things i should replace
if you can see it, you should check it. you may never get a view like this again.
specifics I would go for...leaf spring shackles - these tend to rust in salty winter areas, fuel lines (including filler tubes), brake lines and valves, rear shocks. stablizer bar bushings (if equipped) may be the cause of the popping.
alright guys, i have been playing with the headlights to get them out and i have had no luck, i know where the four screws are but i cant get the bottom ones out. any tips?
also, go to my gallery and tell me what color it should be. i want to keep the red and add something else, like boss 302 stripes but im not sure
let me know
let me know
grapegringo
05-28-2019 03:06 PM
grapegringo
08-19-2016 01:53 PM
Slick96
04-28-2015 05:43 PM
DLG
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
07-03-2006 01:29 PM
Flyer1032
09-04-2002 06:23 PM
