Locking Hood
Old Apr 10, 2006 | 03:38 AM
ford4604bbl's Avatar
ford4604bbl
Cool Locking Hood
OK someone messed with my truck...I don't know when it was or why they did it but they switched my sparkplug wires around. Lucky no damage but took me a bit to figure out what was wrong. What I was wondering was how do I go about locking my hood ...I own a 75 F-250 ..there isn't an inside latch pull on it.
I looked at the handle under the hood and thought maybe I could put some kind of plate steel down behind it and put a padlock on it ...any sugestions? pictures are worth a million
Old Apr 10, 2006 | 04:14 AM
Pre'80's Avatar
Pre'80
Search the salvage yards for a 1979 truck that has one. As far as I know, '79 is the only year to have this option for this generation of truck. Otherwise, try searching the sponsors for an aftermarket one.
Old Apr 10, 2006 | 08:15 AM
F1rocco-NY's Avatar
F1rocco-NY
I switched mine over to a locking hood...Never worked to good even replaced the do-hicky on the latch....So now there isnt a lever...All I have to do is pull the cable from the grill area....
Old Apr 10, 2006 | 08:29 AM
fellro86's Avatar
fellro86
I know of others using the latch from the vans, and cable from the 80's trucks. A little modification may be necessary, but it works.
Old Apr 10, 2006 | 09:19 AM
Craigster1's Avatar
Craigster1
My 78 has a locking hood release handle under the dash that uses the ignition key. I don’t know how tough it would be to find and install one but they did come from the factory.
Old Apr 10, 2006 | 10:21 AM
73Custom's Avatar
73Custom
I got a hood latch from a mid '80s van and used a pull cable from a '83 F150. They both bolted right in, just had to drill a hole for the cable to go through the firewall. The van latch is identical to the optional '78-79 factory pickup latch. It works great.
Marty
Old Apr 10, 2006 | 11:37 AM
X36's Avatar
X36
They offered the factory option on trucks and broncos for 78+79.The latches and keyed handles are the same,but the vans cables are shorter than the trucks and broncos.Good Luck
Old Apr 10, 2006 | 11:50 AM
dakonthemountain's Avatar
dakonthemountain
Locking hood latches that fit our trucks (with inside the cab releases) have often been offered on eBay also... Good luck!
Dak
Old Apr 10, 2006 | 12:10 PM
Munch's Avatar
Munch
I had that same problem with my 78. I drilled a 1/4" hole through the top of the handle and through the supposting braket for the latch and put a pad lock on it. You have a 75 grill tho, the 78 grill has big square openings so it makes it easy to stick a pad lock in there and lock/unlock it.
Old Apr 10, 2006 | 03:26 PM
ford4604bbl
Thumbs up
Thanks for the info I am going to go tomorrow to check out the local junk yard ...wish me luck. If I can't find one there I am thinking that the padlock will work. I was looking at it and it looks like it will work with a small padlock
Old Apr 10, 2006 | 07:17 PM
eedvark's Avatar
eedvark
Heres a cheap one. My '79 F-100 came from New Jersey where they steal batterys.A 1/4inch chain was bolted to the bottom of the hood and hung down so that it could be locked to the bumper brackets. It was sort of a pain in the butt when the hood was open but the previous owner said that his battery never left again.
THartman
30
Jul 13, 2013 03:18 PM
oldbird1965
Apr 2, 2009 10:55 AM
DaFueler
Jan 18, 2007 04:57 PM
raerjim
Oct 15, 2006 06:50 PM
Hellbore
Jun 6, 2006 09:25 AM
