motor & trans mounts for 51 f1
installing tci mII kit in a 51 soon. what did all do for the motor mounts?
buy from who or fab your own, if fabbed own with what and how?
what about trans? my current trans mount does not allow trans to come oiut without motor cause of the mount. did you fab your own or buy?
im buying a pedal booster kit and i tink the stock x member needs to go
i have a modern small block trans combo
Originally Posted by fatfenders
Gwilkrrs
I'm not an MII guy as you know, but I'll take a crack at this. To my knowledge, there are no kits that allow you to maintain the stock transmission X-member, with a modern V8-AT combo. I believe you'd have to severely modify it at the least.
Originally Posted by 49willard
On my F-1, I ground off the rivots and moved the original trans mount back to just behind the tailshaft of the transmission. This did two things. In that the crossmenmber is under the forward end of the driveshaft it seves a function as a driveshaft loop and bolting it back into the frame restores frame rigidity lost without the trans crossmmber (loss of rigidity to frame trist is significant when the original transmission mount is removed from the frame-step on the running board with and without it to see). I installed a second new trans crossmember at the correct location under the transmision. I am running a sbc with a 700R4 AOD. For engine mounts, I had boxed the front so I fabricated and welded new engine mounts to the boxing plates (reinforced at that location)
So you now have two crossmembers about a foot apart at the rear of the transmission? Have you put something back near the stock transmission x-member location to restore the rigidity? All I did was box. Appears to be OK, but I'd prefer a crossmember.
I saw this K member for 48-52 F1 and thought you might like to see it.
http://www.rbsauto.com/product.asp?P...17659&l1=17658
Looks like it would be easy to build from scratch to fit any trans.
raerjim
09-23-2011 09:42 AM
sohcslammer
11-30-2009 07:21 PM
sgoody43
02-25-2008 10:03 PM
rich51fordtruck
05-22-2006 05:34 PM
