Kaboom!!!
Old Apr 10, 2006 | 07:51 AM
Six Niner's Avatar
Six Niner
hey kurt if it makes you feel any better i got the top half of my motor put back together this weekend, got ready to fire it and noticed the valley pan sitting off to the side. oh how i love taking that friggin intake off! any way hope it all works out good for you.
Old Apr 10, 2006 | 10:53 AM
rusty70f100's Avatar
rusty70f100
Problem found!
I took off the valve covers yesterday before I left for my trip. I found one bent pushrod. It was bent down by the lifter. The top cup part of it had a chip out of it. It's matching valve was stuck half open in the head. It's the #6 exhaust valve.
My current theory is that when the machine shop put in the new guides, they left them too tight to the new valves. Take it out to drive it, they heat up, and sieze. Yes, I took the new valves up there so they could match them. And yes, I cleaned everything off VERY good before I put it together.
So the plan today is to take pictures and pull the heads. Not sure how far I'll get, but at least it's close to 70F out, sunny, and no wind. If I get both the heads off I'll go up to the machine shop with 'em, probably tomorrow.
I hope the piston did not come into contact with the valve...
I may just go run the wood chipper. It's a PTO driven DR chipper mounted on a Kubota BX2230. That thing should release the agressions...
Of course, this "server is too busy at the moment" stuff really adds to the agression...
Old Apr 10, 2006 | 04:18 PM
EgoMan's Avatar
EgoMan
LMAO...I thought you were gonna say that you might run the guy from the machine shop through the chipper......
Old Apr 10, 2006 | 04:22 PM
rusty70f100
Ok I took the heads off. The #6 exhaust valve has marks on it where the piston pushed it back up. The piston has some slight marks on it where it pushed the valve up. Nothing broken; nothing I'm going to worry about.
The heads are up at the machine shop right now, getting fixed, hopefully for free. He says he'll have 'em done tomorrow. Edit: I do like the wood chipper idea.
So now I need a new pushrod. I see that Summit wont send out the Comp #7533 pushrod until the 20th, anyone know where I could get it sooner?
Edit again: Never mind, it looks like Jegs will send one out immediately.
Old Apr 11, 2006 | 09:38 AM
Freightrain's Avatar
Freightrain
Glad to hear it was "minor". If breaking a new motor is minor. At least it didn't come out the side!
Old Apr 11, 2006 | 10:57 AM
fordraceboy's Avatar
fordraceboy
my buddy dropped a valve like that one time... except it went through the top of the piston and got hung up and it ended up snapping the cam and the cam came out the side of the block... oops. LOL
Old Apr 11, 2006 | 11:44 AM
4starcstms's Avatar
4starcstms
Glad it wasnt 'too' major of a issue. Let us know how she runs when you get her back together!
Old Apr 11, 2006 | 02:09 PM
rusty70f100
Well, I just got back from the machine shop. They reamed out the guides to the correct clearances. The one valve that stuck, you could see where some material had transferred to the guide. It definately seized due to insufficient clearance.
Jegs has the pushrod backordered. Fortunately the guy at the machine shop can get one in a couple days, so I'm going that route.
Anyway, now I'm going down to Napa to get a new exhaust valve.
OBTW, I've got over $100 worth of gaskets ordered from Summit, if you include shipping. If anyone wants to know, I can list out which gaskets I got.
I'm working on the pictures.
Question:
What do you guys think? Should I put the Performer RPM back on, or port the Streetmaster 390 intake and put that on?
Old Apr 11, 2006 | 02:16 PM
Randyb12's Avatar
Randyb12
Keep the RPM The Street Master won't do anything under 3000rpm. But after that it will make more power.
Old Apr 11, 2006 | 03:30 PM
FalconStng's Avatar
FalconStng
If you go by the "intake shootout" then it suggests the streetmaster may be better...and that's without the porting. However the RPM was almost as good...I doubt that most of us could tell the difference in everday driving...I'm sure I couldn't. Still, if you feel like going through the porting, it would be fun to see if you can tell any difference. I suppose you can be pretty certain that it can't be worse than the RPM. Flip a coin...LOL.
Tracy
Old Apr 11, 2006 | 05:57 PM
73F100*8Mile's Avatar
73F100*8Mile
So kurt how much of this do you think would be due to weak/old gas? I'm gonna fire off my 390 here in a couple of weeks and that gas has been in there since last thanksgiving. I'm really thinking about firing up my electric fuel pump and pumping it all out and adding new.
Old Apr 11, 2006 | 06:11 PM
rusty70f100
None of it was due to old gas. The reason the failure occured was that the machine shop that put in the new guides left them too tight. He probably used smallblock chevy clearances. When the exhaust valve heated up, the stem expanded to the point where it welded itself to the guide due to insufficient clearance.
I took the valves out to the wire wheel to clean them off. I noticed one other one was on the verge of failure, with galling like the one that failed. So now I need two valves.
Edit: Before, I said that pieces of the valve transferred to the guide. That was backwards. There are little pieces of guide on the valve. I'll take pictures.
Re-edit: 73F100, it would not be a bad idea to drain that gas and refill. A new motor really deserves new gas. Plus, it'll increase the chance it'll fire right off when you first crank it over, which is what you want for proper cam break-in.
Old Apr 11, 2006 | 06:36 PM
  #28
73F100*8Mile
While I've gotcha kurt, I'm gonna run a holley reman 600. I don't have any idea where they set the floats from the factory and i have the screw in's, not the see through sights. With an electric fuel pump, is there an accurate way to set the floats to that when the motor fires i don't have to worry about it spittin and sputterin from either fludding or running lean? I'm already planning on gettin the sights but would like to know how to set the floats. Thanks!
Old Apr 11, 2006 | 07:20 PM
  #29
rusty70f100
Well, turn on the electric fuel pump until it fills the float bowls. The set the float so it barely dribbles out the sight plug hole (yes, you remove the plug to set the float and some will dribble out). Your floats are now set and you never cranked the motor.
Normally they're pretty close from the factory. It should be close enough that you wont have to worry about it during cam break-in.
Old Apr 11, 2006 | 07:36 PM
  #30
"Beemer Nut"'s Avatar
"Beemer Nut"
What material are the guides made of? Stems chromed and ground?
I have never seen stem material transfer to the guide as guides are softer as the stem will peel or gall off guide material. You must be running seals vs umbrellas which run guides too dry in my book.
I know you must be running solid rocker spacers, why go thru sucking valves because you gambled on spring spacers "feel lucky?"
.....=o&o>.....
