There's a plug in my plug?
Old Apr 8, 2006 | 05:51 AM
Hotwheelbill's Avatar
Hotwheelbill
I pulled the plug in the dash by the cubby to run my wires for the Brake Controller and there is an electrical plug on it. Is this just a dead plug for the optional peddle adjustment or can I use this for something?
Old Apr 11, 2006 | 08:15 AM
mueckster's Avatar
mueckster
Not sure what plug you are talking about. Is it round or square? On my '01, there is a round plug that was for an auxillary idle controller. I used one of the wires for the ignition power to my gauge pod.
Old Apr 11, 2006 | 09:45 AM
Hotwheelbill
It is a rectangle plug that was clipped onto the back of the small dash plug to the left of the cubby. Seven wires.
Old Apr 11, 2006 | 01:33 PM
ryaneverk2's Avatar
ryaneverk2
I'm not sure if we're thinking of the same one, but once you remove the under-dash cover to access the wiring and fuse panel, to the right inside there, basically below the cubby, is a rectangular hole in the side - and through there is a plug for a trailer brake controller.
Old Apr 11, 2006 | 05:52 PM
Hotwheelbill
I will try and get my camera and computer to talk to each other again and put on some pics. this weekend. I just wanted to know if I can use any of this later.
Pest007
All Things Towing
Feb 12, 2016 01:32 PM
tj90
1997 - 2003 F150
Nov 13, 2013 05:14 PM
Gruntface
Mar 14, 2012 10:24 PM
Dodge/Cummins
May 16, 2011 03:03 AM
hifiman
Sep 15, 2010 10:42 PM
