fuel Pressure ???
Old Apr 11, 2006 | 02:48 PM
Duane99's Avatar
Duane99
fuel Pressure ???
Does anyone know the size of port at the back of the fuel filter canister to hook up a guage to?????
1/4 npt ?????????
Old Apr 11, 2006 | 02:52 PM
Kwikkordead's Avatar
Kwikkordead
1/4 npt ?????????
Is it the same size as the ones on the cylinder head?
Those are 1/8" NPT.
I've never had the one out of the back of the fuel filter housing to know for sure.
Old Apr 11, 2006 | 06:22 PM
Fat Diesel's Avatar
Fat Diesel
It's not NPT, it's like -4 AN or something like that. Dieselsite has the adapter to 1/8" NPT for $6.
http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=217
Old Apr 11, 2006 | 06:34 PM
jtharvey's Avatar
jtharvey
I bought mine at a hardware store for something like $2.00. I just took the stock plug out and went to the store to find comparable threads. But, it is not NPT. Like FD said, it's a straight thread similar to 4 A/N. I think it's a 1/4" or 3/8" flare fitting. Find the adapter to go to 1/8" NPT. The only thing I had to do was grind off the flared part to make it flat. You can also pick up a new o-ring while you're there if the stock one can't be re-used.
