Edge Tuner PIDs
Old Apr 7, 2006 | 11:57 AM
RDavis - OKlahoma's Avatar
RDavis - OKlahoma
Question Edge Tuner PIDs
I've been running the Edge Tuner on Level 2 and really like it. I have also been watching the PIDs display all kinds of good information like Engine temperature, oil temperature, transmission oil temperature, etc. But that is just it, all that I'm doing is watching the numbers go up and down but really have no idea what the operating specifications are for all of the parameters monitored by the Edge.
My question is - Does anybody have a reference source or internet site link that will discuss the normal operating specifications for those parameters monitored by the Edge?
Thanks in advance
Old Apr 7, 2006 | 01:06 PM
DASTUD's Avatar
DASTUD
I Think As Popular As The Edge Is, A Lot Of People Here Would Like The Above Info. Bring It On. I Will Try And Contact Edge Products And See If They Have Anything. I Was Just On The Phone With Them Yesterday Resolving A Minor Problem. I Will Keep You Updated On Any Info I Get.
Old Apr 7, 2006 | 01:52 PM
is300wrx's Avatar
is300wrx
this is very true. I have no idea what to watch out for! I have all the facts, but nothing to compare it to. No parameters..
Old Apr 11, 2006 | 10:07 PM
RDavis - OKlahoma
I found that you can get a short-term subscription (72 hours) for $9.95 at www.motorcraft.com where you can subscribe to the Service Publications, TSBs, etc. The PC/ED Manual, Section 6: Reference Values provides values or operating ranges for normal operation of the vehicle. Most of the PIDs associated with the Edge have a reference value or operation range listed,
Old Apr 12, 2006 | 04:39 PM
derek4343's Avatar
derek4343
if your not overheating and your tranny is working who cares what those numbers are.your factory gauges still work.
Old Apr 12, 2006 | 04:56 PM
RDavis - OKlahoma
I was most interested in monitoring the timing advance in order to keep from approaching detonation (pinging) and engine damage. Normal condition for the SPARK (SPARKADV) is 34 Degrees at 30 mph and 32 - 40 degrees at 55 mph.
Old Apr 12, 2006 | 05:04 PM
Dexsure's Avatar
Dexsure
DA,
What kind of minor problem were you having with your Edge?
Old Apr 12, 2006 | 09:15 PM
DASTUD's Avatar
DASTUD
Originally Posted by Dexsure
DA,
WHEN I LOADED LEVEL 3, CUSTOM OR NON CUSTOM, WHEN I WOULD GO TO PUSH THE GAS, THE TRUCK COMPUTER DISPLAYED FAILSAFE MODE AND IT WOULD NOT ALLOW THE TRUCK TO GO BEYOND IDLE SPEED. I DID THE LATEST UPDATE AND IT SEEMS TO HAVE FIXED THE PROBLEM.
Old Apr 12, 2006 | 11:45 PM
Dexsure's Avatar
Dexsure
Thanks, seems like a good product, just have to wait till I get my f150 and I will pick one up.
Old Apr 18, 2006 | 10:07 AM
spd080's Avatar
spd080
I am having a small problem with my Edge. I have had it about two months now and have been amazed at the performance gains from this product!! However, I recently changed a few settings and now hear a clicking or pinging sound during acceleration. I have the timing adjusted to 1.75 and am running 93 octane fuel and have 3.73 gears. Also I have 305/70/17 on my truck and am wondering what I should be using on the edge as a tire size? Any suggestions would help. Thanks
Old Apr 18, 2006 | 10:20 AM
Dexsure's Avatar
Dexsure
Spd,
Try adjusting your timing, the pinging is coming from an irregular burn. You may have advanced the timing too much for 93 octane.
Dex
Old Apr 18, 2006 | 08:47 PM
RDavis - OKlahoma
Spd-
The manual shows a simple formula for calculating the correct tire size. If you really want to get accurate you can place a chalk mark on the tire and roll the tire to get a measurement that will take into account the tire "squish" from the truck weight. You might want to roll it two or three times to get an average.
I did it both ways and the rolling tire measurement was a little less than the calculated tire measurement (duh?). I used the rolling tire measurement for input into the edge.
Old Apr 18, 2006 | 09:17 PM
spd080's Avatar
spd080
Ok I'll try that. Another question... Will any engine damage occur if I use 87 oct with the performance setting? Seems to run good with ol 87 oct, just concerned about burning valves or something. I just dont care for the tow setting or the trans only setting, they make my truck upshift too much. Thanks for your help.
lhud
Jan 20, 2016 02:56 PM
ssharber
6.4L Power Stroke Diesel
Jul 13, 2012 10:51 PM
kabur66
6.7L Power Stroke Diesel
Oct 14, 2011 06:32 AM
noimports
Jul 15, 2011 08:41 AM
MoyockPowerstroke
Jan 12, 2010 07:10 PM
