Some Very Good Tranny Info
Originally Posted by Casey
That's a very good chart if you are using fluids and materials from the 60's. It's totally useless if you have a modern trans with modern ATF.
on
1 Post
Originally Posted by cangim
Can you expand on the difference in OIL technology, I have yet to see any synthetics that are rated for high temperatures with out affecting oil life. heat breaks the oil down no matter how good or advanced technology has become. It is still oil.
Here is another chart, not from a cooler dealer.
http://www.niehoff.com/techtips/trans.html
Glenn
Originally Posted by Kwikkordead
I thought it was the clutch packs that get toasted and fall apart, not the deterioration of the ATF due to the excess heat.
But on a side note if you have fried your ATF and it's black and smells burnt the fastest way to finish off the tranny is change the fluid. Had a guy come in with a van when I was still working at the chebbie dealer that had towed a boat with the 700R4 tranny, fluid was toast and I at first refused to change it, he insisted and my service manager get him to sign a waiver somehow. I wrote on the back of the ticket that with the fluid that bad I didn't think the tranny would live 50 miles after a fluid and filter change-----it made it 47 miles before it went clear out and had to be towed back to the shop for a new tranny.
BTW that chart looks very similar to what we were taught in tranny class, for every 10deg F. above 175 deg the ATF looses 25,000 miles of service life. And that wasn't some cooler company pushing it but rather a actual school on automatics in the early 90s so guess that throws out the early stone age fluid issue.
