ballast resistor
Old Oct 22, 2002 | 12:28 PM
showle's Avatar
showle
ballast resistor
what is a ballast resistor?
i have a 1970 f-100 with a 302 and im trying to install a pertronix ignition system it says i need to connect the red wire from the ignitor to a connection before the ballast resistor...what do ya'll reccomend...im using the stock coil for now...thanks guys
Old Oct 22, 2002 | 12:43 PM
Triple Threat's Avatar
Triple Threat
ballast resistor
[updated:LAST EDITED ON 22-Oct-02 AT 01:53 PM (EST)]The ballast resistor reduces the amount of voltage to your points style distributor. If you run the full 12 volts to your points, you risk burning them. Which is not good, so I have heard. :] If you are running a pertronix conversion or electronic ignition you do not need the resistor. Anyone else chime in if I am incorrect on any of these points (pun NOT intended).
Old Oct 22, 2002 | 03:57 PM
BB's Avatar
BB
ballast resistor
See if this thread helps: https://www.ford-trucks.com/dcforum/DCForumID73/1358.html
Old Oct 23, 2002 | 07:29 AM
jeremyd72's Avatar
jeremyd72
Post ballast resistor
I know this is alittle off the subject, but does the Duraspark ignition need the ballast resistor? I connected mine to the + side of the coil so I guess I am using it.
Jeremy
Old Oct 23, 2002 | 09:48 AM
BB's Avatar
BB
ballast resistor
Jeremy, yes it does unless you're using the module with the red strain relief.
Click on my gallery to see the progression of the Durafart, I'll leave it turned on for a day or so until I get in trouble.
Barry
Old Oct 24, 2002 | 10:48 AM
jeremyd72's Avatar
jeremyd72
Thanks Barry. Mine is the blue module so I have it right. It came off a 77 with the large cap and wires with .044 plug gap.
Jeremy
Old Oct 24, 2002 | 11:03 AM
jeremyd72's Avatar
jeremyd72
ballast resistor
rasmuspa
Jun 27, 2016 01:36 PM
ihcc104
Apr 16, 2016 08:13 PM
Tparkin99
29
Mar 27, 2016 10:30 PM
FORDF250HDXLT
Nov 22, 2015 08:53 AM
himmelberg
48
Sep 21, 2004 02:59 PM
