Ballast Resistor??
Old Mar 25, 2016 | 06:35 AM
Tparkin99's Avatar
Tparkin99
Ballast Resistor??
Previous owner(s) converted my '86 302 from TBI to 2bbl carb setup, I'm assuming Duraspark or a variation thereof. It cranks everytime, seems to run ok (minus choke/rich issues) but I want to clean up the hack job wiring they did. Obviously, the easy route is to hook it all back up like it is now. However, I've noticed several "extra wires" that go to nothing and that the ballast resistor has nothing connected to it. Since everything "works" should I leave well enough alone or is there a need to have the ballast connected?
Old Mar 25, 2016 | 07:43 AM
Gary Lewis's Avatar
Gary Lewis
What ballast resistor? There are some in these trucks but they aren't obvious, so I'm not convinced that what you are seeing is a ballast. How about posting some good pics of what you are talking about so we can all be on the same page?
Old Mar 25, 2016 | 07:49 AM
Tparkin99's Avatar
Tparkin99
It's aftermarket for sure and installed next to the coil. Looks like the one in this pic but no wires attached. I'll post some pics of the actual when I get home.
Old Mar 25, 2016 | 08:17 AM
Gary Lewis's Avatar
Gary Lewis
None of us can answer the question, only you can. That's because we can't tell what they did. There is/was a ballast resistor in the original wiring, as shown on Page 29 here: Start & Ignition - Gary's Garagemahal. But we don't know if it still in use since someone changed things.
If you have factory-looking wiring, meaning they used a factory harness from a DS-II truck, then the ballast resistor should be in and working. But if they hacked it up, who knows? So, you need to test it. Put a voltmeter on the Batt terminal of the coil, where the W/LB and R/LB wires are in the drawing. With the key on and the engine not running you should have battery voltage. With the engine running you should see the voltage oscillate, and if you have an analog voltmeter it will probably be about 7 - 9 volts because the voltage is dropping across the ballast resistor when the coil is being charged. But, if you don't have a ballast resistor the voltage won't drop much and you'll see something close to battery voltage.
Another way to test is to put your volt meter as above, turn the key on, and ground the other terminal of the coil. Your meter should go from battery voltage to 7 - 9 volts when you do.
Old Mar 25, 2016 | 08:59 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The way to test for the resistor in the harness is to ohm between the coil+ and the harnesses power in run pin of the module socket.
This is outlined in the factory test procedure.
Old Mar 25, 2016 | 09:03 AM
Gary Lewis's Avatar
Gary Lewis
True, Jim. But the inexpensive meters I've been around have a hard time telling a long piece of small wire from that 1 ohm "resistor". However, they are pretty good at seeing the voltage drop.
Old Mar 25, 2016 | 09:10 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Isn't it supposed to be 1.3 or 1.4 ohms?
I'd imagine you could see that, even with a test light.
Where you WON'T see it is reading the coil primary with the engine off.
There's just not enough load to drop the voltage with the coil saturated.
Old Mar 25, 2016 | 09:12 AM
Tparkin99's Avatar
Tparkin99
Ok, thanks. But to rephrase my initial question...what is the purpose of the ballast? To reduce coil voltage to 7-9vdc? Any harm in it not being in play, hypothetically speaking?
Old Mar 25, 2016 | 09:16 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The ballast is necessary to keep the coil from overheating.
Harm will be done to both module and coil without it.
Old Mar 25, 2016 | 09:18 AM
Gary Lewis's Avatar
Gary Lewis
It is supposed to drop the working voltage and current to the coil to prevent burning the coil and/or the ignition module out. And the harm is relative - how badly do you like being stranded on a dark road? Running w/o a ballast will do it.
Jim - Bill's 1986 EVTM shows 1.1 ohm for both DS awa TFM. And, you know that I agree that the meter or even a test light won't drop the voltage enough to really tell when the engine is off.
Old Mar 25, 2016 | 12:06 PM
ctubutis's Avatar
ctubutis
But the OP said he's not even sure what ignition system has been installed....
Old Mar 25, 2016 | 12:21 PM
kr98664's Avatar
kr98664
Here's how I was taught about coils and ballast resistors. It's another way to describe the same thing, but I think it's easier to comprehend:
The coil is designed to run continuously on 8 volts (or whatever the actual value is, but it's less than the full 12 volts). During starting, the resistor is bypassed so the coil gets a full 12 volts for a short period and creates a hotter spark. It's not a problem to bump up the voltage to the coil during the short time the starter is engaged. If run continuously on 12 volts, "Harm will be done to both module and coil without it" (the ballast).
Hope this helps.
Old Mar 25, 2016 | 03:01 PM
Gary Lewis's Avatar
Gary Lewis
Yup. Another reason I asked for pics. We don't know what he has nor how it is wired. All we know is someone replaced EFI with a 2bbl and screwed on a Chrysler ballast resistor. Sure would help to see what is there.
Old Mar 25, 2016 | 06:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It came with this puppy originally...
D7AZ-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-213) / Obsolete ~ Available NOS & from auto parts stores.
49" long / Color coded red with green stripes / 1.30/1.40 ohms resistance / #16 gauge wire.
1977/89: F100/350, Bronco, Econoline & misc. Passenger Cars.
Pic: The Doubting Thomas' can scroll down to 12250
Old Mar 25, 2016 | 06:45 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I guess there is some conflict as to what the resistance really is?
Maybe the replacement differs from what is installed in the harness?
