Sponsored by: Innova
Stock sub box volume
Old Apr 6, 2006 | 04:27 PM
slenser's Avatar
slenser
Anyone know the approximate volume of the sub box on a 2000 Navigator? I have a feeling it's much too big for my sub.
Also, does the padding that is in the box make the sub think it is bigger? I know some people put batting in boxes that need to be a little bigger.
Any help on this would be great.
Sam
Old Apr 6, 2006 | 06:44 PM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
The sound absorbant material on the inside of the boxes are used to help minimize that horrible hollow sound. They help bounce the sound around, so it doesn't reverberate in a box.
Ryan
Old Apr 6, 2006 | 08:55 PM
slenser's Avatar
slenser
I wonder if putting some Great Stuff foam in there would help reduce the volume. I bet it would work great. I might do that to my twin 10" box with 2 Alpine R's. I know there are some leaks and I think they are too big.
Old Apr 6, 2006 | 09:24 PM
RangerPilot's Avatar
RangerPilot
Ok well if there are leaks, filling it up with foam or the like isn't going to do jack crap for it. You need to pull the subs, then find and fix the leaks with silicone. The whole box should be sealed with silicone or the like.
The foam, or poly fill, or anything of that nature, doesn't take up enough space to make a huge difference. Especially poly-fill, you could fill the entire box up and still take only a minor amount of volume. It does make it sound better (pull your door speakers and fill their backfiring areas up, you'll notice a serious difference).
One way I've seen to take up extra volume is:
First calculate the volume required by the sub(s). Then measure the INTERNAL (not external!) volume of the box. If it's made of 3/4 inch MDF, remember that 3/4" takes up space! Figure out the volume that needs to be subtracted to create the ideal internal dimensions of the box. Create some sort of MDF peice that takes up this much space, try and make it an abnormal shape, at least not a box. That way the waves reflect better. Then just glue it in some odd place in the box. Fixes the volume problem, and creates better bouncing waves.
Old Apr 7, 2006 | 12:08 AM
slenser's Avatar
slenser
Well, that stuff is very adhesive, so I figured it would work well for sealing any leaks as well as muffling sounds and taking up the extra space.
Anyway, does anyone know what the volume of the stock box in a Navi/Expedition is?
Old Apr 7, 2006 | 01:08 AM
furball69's Avatar
furball69
See how much water you can pour into it.
kidding, bad steve, baaad.
Old Apr 7, 2006 | 09:07 AM
slenser's Avatar
slenser
Actually, I've been considering that, if no one could come up with an answer. It's plastic, so no harm. I would just have to make sure everything was dry before reinstalling the sub. I'm just hoping someone on here has already done something like that. I may just end up being the guinea pig.
Sam
Old Apr 7, 2006 | 10:53 AM
fordboy_52's Avatar
fordboy_52
wow, someone needs to give this guy some sort of badge. haha
Old Apr 8, 2006 | 08:59 PM
Blinky22's Avatar
Blinky22
Fill the sub box with packing peanuts then take the peanuts out of the sub box and place in a cardboard box with known volume ie. 1’x1’x1’ and measure the un used portion of the cardboard box and subtract from total volume and you will have the volume of the sub box
If box is needed to be made smaller place a piece of 2x4 the size required to reduce the size and attach it to the inside of the box. The shape of the block will not matter as the sound waves produced by a sub at 80 hz are about 14 ft in length.
If the box is leaking you can use thin foam weather-stripping around the sub if that is the problem if not you can coat the hole inside of the box with fiberglass resin.
<O
Blinky
Old Apr 9, 2006 | 02:37 PM
slenser's Avatar
slenser
Hmmm, the ideal volume for this box is .35 cf. That's pretty small. I think that stock box is way too big.
Old Apr 9, 2006 | 03:04 PM
furball69's Avatar
furball69
What does the box look like; dimensions?
Old Apr 9, 2006 | 09:04 PM
slenser's Avatar
slenser
It's the one that comes in the Navigator/Expedition. It's about 1x1x8 for the main part and then has another foot or so, that extends further in a triangle shape. The thing is, it has that sound deadener in there that fills most of it up. Not sure if that takes away from the volume or not.
Swfhawgkiller
Dec 23, 2019 04:18 PM
txazguy
6.7L Power Stroke Diesel
May 8, 2015 06:48 PM
txazguy
Apr 4, 2015 03:48 PM
Tatternubs
Feb 23, 2014 09:21 PM
BrassMonkey
1997 - 2003 F150
19
Apr 16, 2011 04:04 PM
