Sponsored by: Real Truck
Is it the VSS or PSOM?
Old Apr 6, 2006 | 05:25 PM
handyman43358's Avatar
handyman43358
No worries Mike, Don't mind if ya Hijack! lol
Sorry I havent responded quicker. For some reason, it never emailed me to notify me.
Thanks for clearing up that there is no PSOM on these style trucks. Would the O/D light indicate that the VSS is probably bad? Or would it also flash if the instrument cluster module was bad also?
Old Apr 6, 2006 | 06:37 PM
rwilimo's Avatar
rwilimo
Let me chime in with my 2 cents. On occasion a cop can go bad in a way as to spike the pcm when it malfunctions causing all the symptoms described. Depending on how bad the miss you get is will determine if it can be narrowed down to a cylinder.
Option a, bring it to a shop that can do a power balance test on the engine, when the misfire occurs they should see the cylinder#.
Option b, purchase 1 or 2 new cop's (preferably oem ford) and rotate them through the engine until the problem goes away.
Old Apr 13, 2006 | 08:35 PM
Mike Johnston's Avatar
Mike Johnston
Originally Posted by FortyFords
....There can be internal tranny problems that act like a miss(studard or slippage)
and also give the flashing overdrive light.
Now a real good shop should have a computer hook up to determine which cops are bad or misfiring.
Mike when you changed the vss sensor did you reset your pcm by unhooking the battery to alow the pcm to relearn and clear any codes?
was your old sensor covered in grayish particles ?
Rich
Took the SD to a different shop today. At first, they did not get any codes at all even while feeling the miss. They were starting to think tranny trouble, when they finally got a code. It (whatever "it" was) pointed to ALL the cops acting up, according to the tech. They wanted to keep it over night and try again tomorrow.
This is starting to get real old.
Thanks again for all the suggestions.
Mike
Old May 6, 2006 | 12:14 AM
sbro302's Avatar
sbro302
You said one cop was "rusty" if so was it the 4 cop? if so check your heater hose for a leak. Also was the plug clean or fouled from not firing?
Old May 6, 2006 | 09:00 AM
Mike Johnston
3 COPs ended up being bad. The local dealership replaced 6, 7, & 8. Only two showed codes to begin with. They replaced 6 & 8, then 7 started giving codes.
I only had to sell one child to pay for the service. We get her back after seven years of servanthood.
BRay09
23
Jul 6, 2011 09:15 PM
Xclimation
62
Feb 6, 2011 04:05 PM
johnboy427
1978 - 1996 Big Bronco
Mar 7, 2008 03:17 PM
sweet93gt
23
Jun 21, 2007 01:09 PM
Playing_Tough
Sep 26, 2006 08:19 AM
