another inop. speedometer odometer
My speedometer/odometer quick working. It is the LCD type of odometer. My gauge cluster has the Tach. I checked all the fuses. Both under the hood and dash. I actually pulled out the fuses, looked at them, the reseated them.
I sort of checked the Vss. I followed the wiring from the VSS to the firewall. I say sort of, because I didn't hook a voltmeter to the plugs. I did however take out the VSS itself. (I was pleased to see there were no metal shavings stuck to the magnet of the VSS. Unlike the VSS on my 03 Dodge Ram with a third of the mileage!)
Right now I have the gauge removed from the dash. I have read several threads from people with the exact same problem. I forgot to mention, that when I drive the OD light blinks. It doesn't blink if I don't drive, and let it sit and idle.
The LCD on the Odometer does not display anything at all.
Now I've read about the PSOM. I'm not exactly sure what the PSOM is. Is it little circuit board sandwiched between the black gauge faces/needles and the white plastic piece that the black gauge faces are held in by? I had a hard time following others physical description of it. If it is what I described, then I didn't notice anything unusual when visually looking at it. Nothing disconnected or burned. What's a good way to check this?
On another thread, someone had mentioned that there are some people who repair the PSOM, as they are no longer sold by the stealerships. Any recommendations on someone who does this if this is the problem?
To those who solved their problem, how did you do it? On most of the threads, the OP did not come back and tell how and if they fixed the problem! (I hate it when people do this!) It seemed that some fixed it by replacing the fuse. I tried this as stated above.
Thank You in advance!
Good luck with the repairs!
The wiring or the VSS sensor would not cause this.
You either have no power to the PSOM or a bad PSOM.
You do not have the wheel sensors that 97FRD1TN talked about above. Sounds like he has 4 wheel ABS.
The PSOM:
I do not know about a 1997 one ton and newer trucks like yours is why I said that above about your post.
Anyone know where to find a list of all the grounding points? In particular, the one for the PSOM. The wiring schematics I have do a bad job of showing this.
In my truck, also the intermittant wipers do not work, the wiper washer pump does not work. Also, the cruise control does not work. I'm wondering if some of these problems might be related to grounding problems.
Thank You for the suggestions so far!
Get that meter goin', and check the wiring to the PSOM for power. That'll give you your answer. If there's power, you have a dead PSOM. No power, and you've got a wiring issue to figure out.
The ground for the PSOM is G200.
Also make sure the Body Ground is good.
The fuses are in the cab fuse panel numbers 8 & 18.
VSS/PSOM Diagram:
G200 on the Passenger side in front of the door in the kick panel:
Body Ground:
1995 Cab Fuse Panel:
Power into PSOM is on pins 1 & 3. Ground is pin #2.:
what your answer for speedometer that went crazy jump from 10-50 mph while you drive at 35 mph.
We check rear end it good. We notice if we drive on smooth road it stop jump but we have tons bad road here.
I have the same problem, and I'm planning on checking the wiring and connectors that are shown in the schematic that Subford posted above. If everything checks OK, I'm going to get a junkyard PSOM and see if that fixes it.
I have the multimeter set on DCV 10.
I hooked up the red probe to pin 1, then the black probe to some metal on the dash. This is on the PSOM plug. This is the Hot in connection. The needle on the multimeter all the way to the right.
Same thing happened with pin 3 (Hot in Run.) I did have the engine running.
I next touched the black probe to Pin 2 (ground), then Pin 1 (Battery Input) to the red probe. Needle went all the way to the right.
I next did this with red probe to pin 3 (Hot in Run), then black probe to Pin 2 (ground.) Same result, needle all the way to the right.
I am guessing this is telling me that the PSOM is getting power?
I went to the junkyard, and obtained another PSOM from the same year truck. I plugged it in. Same thing (didn't work)
I next touched red probe to solder point on PSOM that corresponded with the pins above, and was getting power at the solder points. I tried touching the red probe to the various capacitors and resistors on the PSOM while touch the ground, and they all made the needle move to the right.
So now I'm really stumped. It appears PSOM is getting power; and I've used 2 different PSOMs with the same result. (I'm not ruling out that I used the multimeter wrong)
I next tried using the multimeter by touching the red probe to pins 4, 5 and 7 one at a time, and the black probe to metal on dash, then ground pin 2. The needle wouldn't move. These pins 4, 5 and 7, correspond with RABS, on pins 4,5 ; and speed output to PCM and instrument cluster. I did not test pin 9 (PSOM programming connecter) because I figured this was for the dealer programming, and I understand it only works 4 times. I didn't want to use up the usage in case I need it. I didn't really figure this would be my problem either.
So now it seems I'm getting power to the PSOM, and the ground is checking out ok. At this point I'm thinking VSS because as I posted before, the OD light starts blinking when driving. I didn't mention that on the Junkyard PSOM, the speedo/Odo is still connected to the Junkyard PSOM. I took it as a whole in case there is a problem with the LCD.
Any suggestions from here, Please? I'm guessing next step is to test continuity at the VSS. How would I do this? Another words, what setting on the multimeter, and which probe to which wire?
Again, Thank You in advance! You all have been very helpful so far!
On a good note, I obtained a wiper control module at the junkyard. I now have for the first time in 3 years (since I bought the truck) intermittant wipers, and the wiper washer works! This after testing that problem off and on for the last 3 years. Auto parts stores don't take returns, on electric parts if that wasn't my problem. I pretty much knew it was the problem, but couldn't justify spending the chunk of change they charge for a new wiper control module, and taking a small chance that it wouldn't solve the problem. The stealership wanting $200 for it. Ebay used (no guarantee $50) Junkyard $15.00, and it worked!
