c6 do i need a kick down rod
Old Apr 4, 2006 | 09:31 PM
alankirby's Avatar
alankirby
Red face c6 do i need a kick down rod
if so where can i get one help
Old Apr 4, 2006 | 11:13 PM
1972FordCustom's Avatar
1972FordCustom
it wont hurt a c6 to run w/o a kick down rod....I have been running mine that way for over a year now....
Old Apr 5, 2006 | 10:48 AM
piperig78's Avatar
piperig78
I'm just about positive the kick down linkage down shifts the trany when you put the gas to the floor, do you need one not nessesarly but truck will perform better with it, i would check junkyards for one
Old Apr 5, 2006 | 02:14 PM
woods's Avatar
woods
I may have a factory kickdown rod that goes from the linkage on the tranny to the carb linkage for a 1970 F-250 2 barrel .
Let me know if that is what you are looking for.
I will check my garage to see if I didn't toss it and I will send it for the cost of shipping
Old Apr 5, 2006 | 02:52 PM
ivanribic's Avatar
ivanribic
You can also buy a cable kit off ebay or from Lokar that will replace the rod. The tranny doesn't need it, but it is a nice feature for drivability.
If you want some fun reading for an otherwise dismal day check out this thread regarding kickdowns: https://www.ford-trucks.com/forums/s...d.php?t=304742
Old Apr 5, 2006 | 03:24 PM
tjc transport's Avatar
tjc transport
i ain't rite
wow ivan .that WAS a good read. i guess that the c6 in my 79 blew up when i put the 4 barrel on it and did not hook up the downshift rod. i just never knew it.
and the C4 in the falcon must have blew up back in 85 when i put the e-brock4 bbl on it without the downshift bellcrank assembly, and i didn't know about that one either.
i guess that explains the fact that every time i mash down the go pedal the rear tires go up in smoke. i blew the tranies with no ds rods, and then the trans put to much power to the rear wheels, huh???
Old Apr 5, 2006 | 06:09 PM
RTM's Avatar
RTM
I didn't read all of the post but the one psoting about needing the kick down is reffering to an AOD tranny not a C6. Yes an AOD tranny has to have a detent cable which is not a kick down rod. They are two different animals. A c6 and a c4 can be driven with out the kick down rod. i as well as others have done so for many miles with no issues.
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
