Can any boby help I can't find a o.e. wireing harness if my life depended on it mostly because I Just don't know where to look if. I'm very close to the end of my project but can't get on the street with out tail,and blinkers and all that good stuff you need for ins. thanks
I can't think of the manufacturers names. If you will search Ebay, I'm sure you will find some. They may not be exctly for your truck, but it should provide a manufacturers name that you could then search for via the web.
search for something like "wiring harness truck" or the like.
MSD wiring is straight forward. Especially, since I have their Billet Distributor as well. If you are running now with stock style components, the MSD unit will come with everything you need: with or without their distributor.
Painless wiring: I could not rememeber the name. I knew I had see some ads.
I got the truck from the orig. owner and it had it already.
this is a good question because I have never seen any other truck like it on the street. I'm thinking of taking it off and duplicating it cause I've looked around at differnt aftermarket co. and this is not avalible at the places I've looked at.
