Only 25psi?
Old Apr 3, 2006 | 08:46 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Only 25psi?
Well, my ITP overboost kit came in today. happily ripped the Dual Relief Valve out, and put in the regulator. went to town to the ATM for fuel money, and i took a route that was slightly uphill and then leveled out that would let me get into it. i shifted into 2nd, locked the TC at about 1200 rpm, then just cruised along to about 30mph and then mashed the pedal. boost piled on amazingly fast, and i held 25psi constantly. im amazed that it wouldn't go over that. i held it in third, (OD off) but it didnt want to shift. finally it shifted into 3rd (still at WOT) and the boost jumped to 29spi and PSSHWTT.. there went the intercooler pipe. limped a hundred yards or so to a safe place to pull off. man how embarassing it is to sit alongside the road with your hood up as cars go by and look. THANK GOD i had the 11mm wrench i needed to put it back on. not that im too worried about it because 25psi seems to be my sweet spot, but do you think it is a fuel problem? maybe a pump?
Old Apr 3, 2006 | 09:57 PM
Lushman's Avatar
Lushman
I would say it is an IC boot problem
Old Apr 3, 2006 | 10:01 PM
guzzle92's Avatar
guzzle92
Seriously, that could have been the problem. If it blew at 29, it was probably leaking at 25. Next time, use the hairspray without the foo-foo smell....
Old Apr 3, 2006 | 10:02 PM
beeglej's Avatar
beeglej
HAHAHAH
Hello Mr. Obvious
I Needed that laugh.
Christof13T
49
Mar 20, 2013 07:08 PM
LaBlacky
May 15, 2012 02:03 PM
ol-blu
Dec 20, 2011 10:03 PM
goosehunta
Mar 4, 2011 08:20 PM
SLAMMIN 22
19
May 17, 2010 08:03 AM
