Well, I only say overkill there because I have 2 fuel pressure gauges. One on the regulator in the engine compartment and the other one in the cab. But, it may not be overkill since I [obviously] can't see the one on the regulator while I'm driving.
I agree. Besides, at idle you can look at one then compare with the other and rest assured they are both functioning properly, or something is amiss. BTW, I was referring to your pillar mounted gauge in the previous post.
True. I have noticed that the Autometer typically reads about 1-2 psi lower than the Marshall that's mounted on the regulator. Not that it really matters, as I'm sure a problem would show up as a bigger difference than that though.
