Electric Choke Question
Old Nov 6, 2002 | 11:39 PM
comet's Avatar
comet
I have been having carb problems with my '71 F250 and am giving up trying to save the original Motorcraft after several failed repairs and rebuilds. I have an old Holley with an electric choke sitting around from a prior '71 F250 I once owned. I don't remember how the wiring was set up for the electric choke, though. I assume it is to be connected to an ignition hot source. Can anyone help me out here?
Thanks
Old Nov 7, 2002 | 12:14 AM
BB's Avatar
BB
Yeah it's gotta be hooked up to something hot when the key is in the ON position only, it must be 12 volts.
You can splice into the red/green stripe wire on the ignition switch "C" terminal (don't go for the pink one, it's the resistor wire) or if you got an amp meter just splice into the green/red stripe wire on the "S" terminal of the voltage regulator.
Barry
Old Nov 7, 2002 | 08:36 PM
Mike W's Avatar
Mike W
I just put a Holley electric choke cap on a 2100 carb. I connected it to the stator terminal of the alternator. This runs it at 7 volts. I compared it to operating at 12 volts. It is slower on 7v, I liked that better. :7
Old Nov 7, 2002 | 09:01 PM
BB's Avatar
BB
Really?! I've tried it and it never opened up fully when it was on the index. Had to adjust it so it barely closed when cold outside.
Barry
Old Nov 7, 2002 | 11:05 PM
Mike W's Avatar
Mike W
I lubed all the linkage real good. Seems like all the stock Ford manuals that I have seen had the choke connected to the stator. Will keep checking it. Regards, Mike
Old Nov 8, 2002 | 12:38 AM
BB's Avatar
BB
Yeah the Ford electric chokes hooked up to the stator but they were designed for 7 volts. It was an electric assist to speed up the pull-off rate. You still used the old-fashoned heat pipes from the exhaust manifold for the main choke heat though.
Hey but if yours works more power to ya!
Barry
Old Nov 8, 2002 | 07:58 AM
jstrauss's Avatar
jstrauss
'77 F100 Custom
Dec 6, 2016 09:01 AM
Mdc9966
Sep 16, 2015 11:20 AM
Tkc432
Jun 27, 2015 01:00 PM
jons67
Jun 21, 2006 06:37 PM
dmullins1006
Mar 18, 2004 01:52 PM
