1978 - 1996 Big Bronco
Bronco/F-150 Tailgate Compatibility
Old Apr 1, 2006 | 11:49 AM
95bogginbronco's Avatar
95bogginbronco
Hey guys,
I own a 1995 Bronco with a severly rusted tailgate. I was think of ditching the top and using a soft top or keeping it open. I haven't decided yet. This struck is not my daily driver if that helps at all. My question is will a f-150 tailgate work on a bronco? If they do work, what years. Thanks guys.
<!-- / message -->
Old Apr 1, 2006 | 04:07 PM
Streetgang's Avatar
Streetgang
Thats a very good question......I think you will need to go out there with a tape measure and start writing down some numbers!
let us know what you find!
Old Apr 1, 2006 | 06:03 PM
McLeod's Avatar
McLeod
The Bronco tailgate is at least twice as deep as a pick up tailgate.
To get the outside sheetmetal to line up, there will be about 3 inches of gap at the inside floor area.
Old Apr 1, 2006 | 09:52 PM
greystreak92's Avatar
greystreak92
Not to mention that the hinges are completely different and the latches are in different locations.
Old Apr 3, 2006 | 02:59 PM
BroncoRoadKill's Avatar
BroncoRoadKill
It would take some welding and fabwork. If you have any of those skills, you can do anything you want.
Old Apr 3, 2006 | 03:52 PM
Encho's Avatar
Encho
The Southernmost Mod
It will be easier to find a Bronco Tailgate, if you are planning to change the top you could just seal the window orifice, because the new top will have it´s own window.
Old Apr 3, 2006 | 04:01 PM
95bogginbronco
I live up in east central minnesota where salt eats everything. It is difficult to find a decent bronco tailgate around here. It is alot easier to find a f-150. Another option would be to get a new one as a shell and either put my stuff in it or leave it empty. Any ideas guys? thanks for the info so far.
Old Apr 3, 2006 | 05:09 PM
dwoodler's Avatar
dwoodler
If you aren't going to use the window I'd get a new shell and leave it empty. Then seal the top over and run it with the top off. Treat the inside liberally with an anti-rust agent and Bob's your uncle!
phil atlas
Sep 26, 2006 07:42 AM
Texmo
May 4, 2006 12:42 PM
Jeff Fisher
Apr 17, 2006 09:58 PM
smallblock351w
Mar 25, 2006 08:05 PM
backhoeken
Electrical Systems/Wiring
Jan 10, 2006 06:37 PM
