pointless ignitions (electronic)
Old Nov 2, 2002 | 05:30 PM
kens72highboy's Avatar
kens72highboy
Post pointless ignitions (electronic)
Does any one have one on there truck? if so do you like it, and would you recomend it to any one else? are they any good?
Old Nov 2, 2002 | 08:26 PM
Mike W's Avatar
Mike W
[updated:LAST EDITED ON 02-Nov-02 AT 09:27 PM (EST)]The easiest way to do it is to put on a MSD ignition. You can run it with points and then pick up a stock Ford distributor used with the Duraspark box. The MSD will trigger off either one. Later on you can add a box that allows you to vary the timing while you drive from a **** on the dash.
Old Nov 2, 2002 | 09:47 PM
rleblanc1's Avatar
rleblanc1
I used a pertronix ignitor in my 65 mustang, and liked it alot. I have one on order now for my 71 F100.
If you need something inexpensive, it is probably cheaper than an MSD setup... I paid $60 for one on eBay. You can find more info on them here:
http://www.pertronix.com/
Old Nov 3, 2002 | 10:30 AM
390fe's Avatar
390fe
I've installed the Duraspark setup on my old '70. Works great, but I miss my points.
Old Nov 3, 2002 | 04:30 PM
hhead's Avatar
hhead
[updated:LAST EDITED ON 03-Nov-02 AT 05:32 PM (EST)]the easiest ignition sysem by far is the DUI. HEI converted for Ford, just one 12v wire and that's it. no boxes on the fender, no ugly wires, no coil sticking up. when you order one, they take your specs and curve your distributor for you. been running one on my stang for 6 yrs without ONE problem!!! bought one for my 67 F250 Camper Special 390FE. fired right up after dropping it in!
http://performancedistributors.com
Old Nov 18, 2002 | 12:09 PM
GolferSA's Avatar
GolferSA
Ken...
Stock .352, 2bbl... trying to be more fuel efficient, and get better performance. Just picked up the Pertronix Ignitor with high voltage coil (eBay), have the 7mm wires on order and installing Splitfire plugs...
Question What's the best recommendation for a cap and rotor to hold up to the increased spark, or is stock ok?
Open to suggestions, thanks!
GolferSA
67 Ford F100 Custom Cab
352V8 C6 Auto Factory Air
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5688&.jpg
golfersa@netscape.net
Check out my gallery!
Old Nov 18, 2002 | 11:09 PM
Pyrate's Avatar
Pyrate
I have a 68 F-250 camper special with a 360 and RV cam. I was having problems with my point slipping all the time and losing thier gap. I put in a pertronic system and could not be happier. I had one set go bad but was exchanged with no questions asked. That was 5 years ago and check the gap every tun-up but o other problems yet.
Old Nov 18, 2002 | 11:55 PM
Mil1ion's Avatar
Mil1ion
ElwoodMurphy
Nebraska Chapter
Mar 22, 2017 07:11 AM
JasonB1
Oct 27, 2016 03:26 PM
80ford100
Jun 21, 2016 11:29 AM
mackda600
Oct 29, 2010 02:18 PM
XLTdav
Appearance & Dress-Up
May 29, 2003 01:58 PM
