FOUND: my lost mpg
Old Apr 2, 2006 | 08:30 AM
Jerrod's Avatar
Jerrod
Kwik,
Is there an economical place to get a stock bosch replacement? Any idea on part numbers? Is this a suitable option to jsut replace the stock with another stock bosch?
Old Apr 2, 2006 | 08:52 AM
clux's Avatar
clux
Originally Posted by Kwikkordead
In ideal conditions a fuel pump should last at least 200,000 miles. Ford's pump is made by Bosch. Bosch also makes fuel pumps for the VW and Audi's that I work on every day.
What kills these pumps is air in the fuel.
Where the air comes from is the quick connects on the fuel line from the tank to the pump and, if one insists on running thier tank low all the time, from the mixing chamber in the fuel tank pickup.
To expand on that I'm sure the demise of my pump was mostly my fault. A year ago after the first bad tank of fuel my pickup gelled at the fuel pump screen, I was in the middle of nowhere and continued limping along until my help showed with a bottle of 911. Again this December I gelled about 2 miles from home and instead of parking it I limped on home (took about 20 minutes). Both those incidents correlate to when I saw a marked decrease in economy, I'm sure I damaged the pump by running it out of fuel and overheating it.
I would advise everybody to check their fuel pressure before the run out and buy a new pump.
Old Apr 2, 2006 | 09:00 AM
Kwikkordead's Avatar
Kwikkordead
This is the smartest thing to do. New pumps retail for more than $200.00. You can get a guage for less than half of that.
Old Apr 2, 2006 | 08:35 PM
BowDown's Avatar
BowDown
LOL
Then what if you find out you need a pump. Then you wasted like 100$ on a gauge you will prbly never use again.
Old Apr 2, 2006 | 09:26 PM
Kwikkordead
Originally Posted by BowDown
LOL
Point taken.
You have to ask yourself now if you want to play it by the seat of your pants, take a guess and make a decision on whether you need a pump or not.
Or just take the plunge and buy one, stick it in and be done with it.
Going on the failure rate of the fuel pumps here on FTE, your chances are pretty good that you'll need a pump. So I guess you could just save the money and go buy a pump.
Old Apr 2, 2006 | 09:36 PM
maevans's Avatar
maevans
Kwik - Replace with a stock pump or is thier a after market pump you can recommend.
Old Apr 2, 2006 | 10:32 PM
clux's Avatar
clux
LOL
LOL
It's your money. Then what if you find out your pump is good? I got a brand new $300 ford factory pump for $100 from a guy who used that method. For $100 you can install an in the cab fuel pressure gauge and know what your pressure is doing all the time. Or you can get an idea of what your fuel pressure is at the test port with a cheap tire pressure gauge. I like to try to diagnose problems rather than just throwing parts at it.
Old Apr 2, 2006 | 11:14 PM
empiretc's Avatar
empiretc
I got a pump from oh-rye-lees for $100 when I was having fuel delivery problems. Turned out my old one was fine so now it rides in the toolbox as a spare.
Old Apr 3, 2006 | 08:13 AM
Kwikkordead
I think the stocker will work just ok, but here's what I did.
https://www.ford-trucks.com/forums/s...d.php?t=440448
Old Apr 3, 2006 | 09:00 AM
sglaine's Avatar
sglaine
Posting Legend
Point taken.
(LOL) Great point there.
Old Apr 3, 2006 | 09:42 AM
Craze's Avatar
Craze
So whats the first clue you need to replace the pump?
Old Apr 4, 2006 | 05:45 AM
Kwikkordead
What clued me was the powerband was greatly reduced above 2500 RPM - even with a brand new fuel filter. It was acting like a clogged filter. After replacing the pump, I got a touch more power at the bottom and mid range, but above 2500 RPM - well it takes half the time to get to 3000 than it used to.
Old Apr 4, 2006 | 10:26 AM
  #28
sglaine's Avatar
sglaine
Posting Legend
That makes sense to me. I used to drive an Ambulance that had to same issue and after the pump was rebuit the power and mileage was back.
Old Apr 4, 2006 | 11:18 AM
  #29
monsterbaby's Avatar
monsterbaby
Well I just checked mine today for the first time since installing the prepump pump, and I got 16.9 (lieometer says 16.7) so there is the possiblilty that the main pump is getting bad, and the prepump is covering it up or extending the life of the main pump depending on how you want to look at it.
Old Apr 4, 2006 | 01:51 PM
  #30
Kwikkordead
Did you get a chance to check the pressure?
