SAFELY jacking up 5th wheel
Old Mar 31, 2006 | 08:56 PM
jwearly's Avatar
jwearly
Any suggestions for jacking a 8000# 5th wheel?
I need to check the wheel bearings. My trailer is 3 years old and has never been done. ( silly me )
Also thinking of the inevitable flat tire.
I want to be as SAFE as possible.
I have 4 wheel chocks ( Plastic / fiberglass?) and plan to do this hooked to truck with truck parking brake set and opposite side tires ( 2 axles) chocked.
Should I get a hydrolic bottle jack or something else?
Old Apr 1, 2006 | 08:38 AM
MC1's Avatar
MC1
floor jack is best, bottle jack will work too
Old Apr 1, 2006 | 09:54 AM
Colorado-native's Avatar
Colorado-native
I have seen those plastic chocks shatter into many pieces - use something more substantial like the chocks for big rigs.
Get a heavy duty pair of jack stands and use them under the frame when you have the trailer up with the wheels off. They could save your life if the jack slips or fails.
Old Apr 2, 2006 | 07:08 AM
cangim's Avatar
cangim
Agree with all above. I use bottle jacks mainly, one they are cheaper, and two hold more weight than floor and are easier to store. That said, happy greasing, I have to check mine out pretty soon as well. Also a good time to clean out and service brake drums if needed.
Old Apr 2, 2006 | 06:08 PM
rebocardo's Avatar
rebocardo
Two eight ton (16k) jack stands and a 6k floor jack to lift it. Bottle jacks are okay as long as they have a saddle. Use solid rubber chocks or heavy metal ones, the plastic ones can break as someone correctly pointed out. I chock the back and front of a wheel.
Old Apr 3, 2006 | 05:12 PM
nkfd110's Avatar
nkfd110
If you drive the front tire up onto a block of wood, the rear tire will be off the ground with no jacks needed.
Old Apr 3, 2006 | 05:29 PM
cangim's Avatar
cangim
yeah, but that would be the easy way to do it
Old Apr 4, 2006 | 07:33 AM
SLE's Avatar
SLE
I think we are making to much of this. I actually have all of my tires off my TT at the moment, did it just this weekend and it'll probably stay this way for tow weeks. All I used were the stabilizing jacks, tow 3 ton jack stands, the hitch jack and a 3 Ton floor jack. I simply put the floor jack under one side jacked it up off the ground, placed my jack stand undernieth (behind the rear tire), went to the other side and did the same. at this point it'll be sitting on 3 points, the two jack stands and the hitch jack. On yours, because its a FW, it'll be sitting on four points due to your front jacks. I then simply cranked down all four of my stabilizer jacks and called it good. you'll then have 6 good solid attatchment points that are in direct contact with the ground.
defekticon
All Things Towing
24
Nov 24, 2016 02:52 PM
raynkel
All Things Towing
Oct 22, 2016 01:00 AM
SixStringMadness
Jul 23, 2015 01:13 PM
scraprat
All Things Towing
Jul 15, 2011 06:32 AM
Champ198
2004 - 2008 F150
Dec 12, 2005 02:20 PM
