Safe way to lift 5th wheel?
If I wanted to remove the weight from the suspension on my trailer to get new tires put on. What's the safest method to remove the weight from the suspension without damaging the axles or frame of the trailer? I've seen high lift hydraulic bottle jacks for sale that seem like they're designed for this purpose, but I'd like to see what others are doing. My trailer is too high and heavy to use a standard bottle jack or car jack.
Some guys use a tandem tire changing ramp (I never have). I prefer to crib with heavy wood blocks (6x6 posts). I do that when inspecting brakes and repacking bearings. Also did that to replace equalizers and spring bushings. Set the camper frame down on the cribbing and it's very stable. For a jack, I have a 5 ton bottle jack I position under the camper frame and on top of some cribbing blocks.
Most often I do the same. It really isn't too hard to do. I use a 12 ton bottle jack and it handles the weight easily.
Received 6,671 Likes
on
I honestly don't know why. My owner's manual says not to and I didn't want to find out why the hard way...especially since it's just as easy to jack on the frame.
Occasionally borrow a flat bed goose neck trailer from a buddy. It has tandem torsion axles. He told me to use his tire ramp if I get a flat...says I can damage an axle by jacking on it. He's the kind of guy who always has good reasons and it's his trailer...so I'll do it his way if needed.
My reasoning is that axles are hollow and by jacking directly on the axle you are concentrating the entire load onto an app. 1" square section of it.
on
Agreed here. My 5er has the reverse shackles and the frame is quite high. It's easier to use the U bolt location and then just put cribbing wherever I want to support it for safety.
