I am the proud owner of a 1968 F-250 Camper Speical. I need a new brake drum for the front. At the local parts soter nietehr one of thier numbers match what I have. Did Frod do something strange with this truck or has it been changed. I need all the help I can get on this. Thank you very much.
To replace a front brake drum on my 70 f100 i just took the wheel bearing out i never touched the studs
STeve
1970 f-100 Custom 302 2bbl 4 on the floor, my "economy" machine 1970 F-100 Sport Custom 390 2bbl 3 in the tree with factory overdrive.
1978 F-150 Custom turned into a dune buggy 300-I6 4 speed
Im a typical teen, i just have to change it!
On a old truck, I would replace both drums and the wheel bearings, shoes, brake cylinders and rubber brake lines. If all these parts are in good order, I would look for a part number on the other drum. Check with other parts suppliers and try using a newer year model when you are talking to the counter person. I usually lie and ask for parts for a 79 F150. 90% of the stuff fits just fine.
William in Atlanta
