Big Brake Kits?
Old Mar 7, 2014 | 06:15 PM
DBLX's Avatar
DBLX
Question Big Brake Kits?
Has anyone tried a big brake upgrade on the front brakes? If so, by who and what were your results? I'm tired of the warped front rotors. I need improvement.
Old Mar 7, 2014 | 06:31 PM
MCDavis's Avatar
MCDavis
A big brake kit can still warp...there's no guarantee there.
I use a local 4wd shop for my work and advice. Their master mechanic will advise this...ditch the really high end rotors, and buy the chinese made typical blanks for $50 a piece. He advises to spend really good money on a good solid pad. He's a Ford guy, drives a very well cared for 2002 F350 7.3l diesel. He talked me into $53 rotors, and the best Motorcraft pad we could buy for my 2006. Why MC pads? They come with all the springs, clips, shims, etc so you don't have to reuse existing equipment. Most aftermarket pads won't include all of it. His theory, run the inexpensive rotors til they warp, throw them out, rinse, repeat. For $50ish a piece you can go through 3-4 sets before you reach the cost of one aftermarket kit.
I ran that inexpensive rotor and good pad combo for 35k miles and didn't have the issues that I had in 8k miles on the prior rotors.
I know that's not what you wanted to hear. However, Bear, SSB or Brembo would be my choice if I was dead set on spending hundreds to thousands on a big brake kit.
Old Mar 7, 2014 | 07:01 PM
KJ Smith's Avatar
KJ Smith
There was a huge write up about brakes on the Diesel Stop several years ago.
Warp rotors are somewhat of a myth..... its variable rotor thickness.
Either way same result.... basically the same fix.
The fix is easy enough..... lube the caliper pins with the correct grease (silicon based grease) and use a more aggressive pad (as stated above, MotorCraft works).
You can change your rotors if you want, but the more aggressive pads will true the rotors back up over time.
I went through this with my '02 250. Solved the issue. Just remember to re-lube the pins every now and then.
Old Mar 8, 2014 | 12:35 AM
CuNmUdF250's Avatar
CuNmUdF250
stumbled onto that a few years back.....old timers don't want to believe it but the evidence is there to support the claim that rotors don't in fact "warp"
Old Mar 8, 2014 | 08:49 AM
Tom's Avatar
Tom
JK and Cunmud are correct, and driving style has far more to do with warping rotors than anything else.
-Warped- Brake Disc and Other Myths
Old Mar 8, 2014 | 10:44 AM
KJ Smith's Avatar
KJ Smith
I am an old timer....
I wasn't convinced until I followed the guys advice..... and it corrected the problem.
Hard to argue with results.
Old Mar 10, 2014 | 09:57 PM
Bronc1's Avatar
Bronc1
I have a 2011' F-150 5.0 and had the rotors turned for the first time at about 15K than again at 27K. To solve the problem I purchased expensive drilled and slotted rotors, it didn't help so I had the original rotors turned a third time put them back on the truck and purchased Pep Boys OEM pads, I now have about 45K on the original rotors and PB pads and no warpage, problem solved. I believe the FOMOCO pads are generating too much heat when the brakes are applied. Just my 2 cents.
Old Mar 11, 2014 | 05:40 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Someone mentioned an "aggressive" pad. What does that mean?
Old Mar 11, 2014 | 07:05 AM
MCDavis's Avatar
MCDavis
Tim I've found that ceramic pads are a little more prone to scraping the rotor as compared to a similar semi-metallic. The ceramics that I had on my Explorer were pretty good...came from Napa if my memory was correct.
The MC pads that we put on my '06 gave me no issues and it's no secret that I drive my trucks hard at times. I wish I could find my invoice from 2011 to locate that MC part #.
Old Mar 11, 2014 | 08:42 AM
KJ Smith's Avatar
KJ Smith
Aggressive pads will wear the rotor more.
In this case, it will help "true" the rotor up over time.
Old Mar 11, 2014 | 04:01 PM
RigTrash601's Avatar
RigTrash601
I warped my stock rotors @ 12K, my fault though, I had them turned and then went ahead an ordered EBC Sport rotors that are slotted and "dimpled" (not drilled) for $415.00 a pair and Hawk Ceramic pads for $82.00 a pair. I haven't had any issues since, which I haven't driven as "aggressively" since either and virtually no brake dust. I've heard of other folks that have had problems with EBC, so far that hasn't been the case for me. Baer and Hawk also make good kits, so I'm told, for the F150. As far as the big brake kits, they are really expensive, or at least the ones i've priced.
1978Crew
25
Dec 26, 2016 06:03 PM
DBLX
2009 - 2014 F150
Jan 8, 2014 05:01 AM
TRHOD121
Jan 21, 2013 06:31 AM
KMUL
Jan 10, 2010 01:16 PM
05F-250FX4
Sep 2, 2006 10:04 AM
