Dana 44 build up...
Old Mar 31, 2006 | 12:09 AM
jinxed's Avatar
jinxed
Dana 44 build up...
I'm buying a Dana 44 from a 78-79 F150 it's been gutted... My Question is can I use the hubs from a 3/4 ton or 1 ton truck... Reason for doing so, I'm mating it with a 6 or 8 lug Dana 60, for a rock crawling Jeep...
Old Mar 31, 2006 | 07:40 AM
teds74ford's Avatar
teds74ford
A ford 3/4 ton spindle has the same 5 stud mounting as the 1/2 ton. You can bolt the stuff directly on.
Old Apr 1, 2006 | 02:56 PM
SoArkSI's Avatar
SoArkSI
how much more heavy duty is the 3/4 one compared to the half ton?? where is it beefier at??
Old Apr 1, 2006 | 04:34 PM
Franken-Truck's Avatar
Franken-Truck
Well, if you swap the knuckles out from the 3/4 ton as well, you get flat top knuckles and can do crossover/high steer.
Wheres the beef? Knuckles. . .brakes are dual piston 1 ton jobbers. . .hubs are 8-lug, but are 1/2 ton internals and bearings. Big reason to go 8 lug up front is for the flat top knuckles and big brakes and/or to swap an 8 lug rear in without having to carry 2 sets of spares (5 and 8 lug).
Old Apr 2, 2006 | 10:35 AM
jinxed's Avatar
jinxed
Thank you, thats what I was hoping for... I wanted to make sure the Idea would work first... Jinx
Old Jun 7, 2006 | 01:41 AM
mike240zt's Avatar
mike240zt
just curious about progress on this as i want to do this in the near future. going to be putting a dana 60 under my 12/78 f150 and change the front to 8 lug. i have 79 3/4 ton donor diffs. its my understanding that the ball joints are the same. now will my 79 f150 steering or tie rods fit the 3/4 ton flat top knuckles so i could make the high steer another project at a later date? also if a stub axle from a full time 4x has the circlip groove further inboard than a stub from a regular 4x stub, does it need to be changed to the latter? out of curiosity is a 74 f100 4x dana 44 housing worth using? its only 2 and 3/4 inches outer dia. radius arm mount looks to be located different. any more insight on this axle?
scottf250us
Offroad & 4x4
Jul 15, 2009 08:09 PM
Snowking
Apr 24, 2006 11:41 PM
diesel460
Aug 17, 2004 09:56 PM
nick
Offroad & 4x4
17
Apr 12, 2004 11:15 PM
fearthis390
Dec 20, 2002 10:34 PM
