funny noise. fuelpump?
Old Mar 30, 2006 | 08:11 PM
hedhntr's Avatar
hedhntr
Some times when waiting for the glow plug light to go out it sounds like a motor running under the hood, Like a fuel pump. Sometimes it does it sometimes it dont and it dosent quit untill the motor starts. Seems wrong to me because it dosent always do it. any Ideas
Old Mar 30, 2006 | 08:17 PM
SpringerPop's Avatar
SpringerPop
Could be your vacuum pump's motor that you hear.
Pop
Old Mar 30, 2006 | 08:41 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I think so too. Maybe a small vacuum leak. You shoul dbe able to hear the fuel pump the same every time (or not hear it). The pump gets really loud when it starts giving you fits.
Old Mar 30, 2006 | 08:45 PM
hedhntr's Avatar
hedhntr
Where would the vacum pump be located. And should I take care of it right away
Old Mar 30, 2006 | 08:53 PM
Mustardhead's Avatar
Mustardhead
The vacuum pump is on the passenger side of the engine. There's a vacuum canister right in front of it. Diesels don't have any vacuum so they need a little pump to power things like your vents and 4x4 hubs. You can't hear it when the engine is running. Sometimes it needs to build vacuum, sometimes it doesn't. Unless your vents and hubs stop working, it's fine.
Old Mar 30, 2006 | 09:03 PM
hedhntr's Avatar
hedhntr
cool. It probably is running after shes fired up I just cant hear it. Thanks
kenlee
Jul 19, 2011 07:23 PM
little boatman
Electrical Systems/Wiring
Nov 5, 2008 06:17 PM
tomrooster-1
Nov 29, 2007 08:29 PM
fordxfour87
The Next Generation
Mar 6, 2006 04:44 PM
8996EBBroncos
Dec 4, 2002 01:40 PM
