96 Psd
Old Mar 29, 2006 | 11:07 AM
legacy76's Avatar
legacy76
96 Psd
I am having a problem with my '96 F-250 PS. When I shift into a gear and try to accelerate the engine bogs down for approximately 2 seconds then begins to accelerate. Other PS that I have driven do not do that. I was wondering if anyone might know what the problem is?
Old Mar 29, 2006 | 06:08 PM
trike1946's Avatar
trike1946
Is your CEL on? Have you checked for codes? How many miles on it?
Old Mar 29, 2006 | 09:19 PM
legacy76's Avatar
legacy76
What does CEL mean? I have checked for codes and haven't found any. The truck has 188000 on it.
Old Mar 30, 2006 | 05:32 AM
trike1946's Avatar
trike1946
Check Engine Light. Have you done any mods lately? Last service? Could be a problem with the accelerator pedal. There is no cable. It works with a sending unit. I just had to replace mine. Are you using diesel kleen or anything like it?
Old Mar 30, 2006 | 10:34 AM
legacy76's Avatar
legacy76
I have put an edge evolution on recently, but it did this before I ever put it on. I service it regularly and I don't use diesel kleen. The CEL is not on. This problem doesn't occur all the time, it occurs probable 70% of the time.
Old Mar 30, 2006 | 11:24 AM
tjbeggs's Avatar
tjbeggs
what are the temps outside? does it ever do it after the truck is warmed up? does the exhaust sound any different. could be the exhaust backpressure valve closing then opening. if its cold out could be normal operation. it closes to help warm the engine but when you accelerate its commanded open but there could some lag to it.
Old Mar 30, 2006 | 11:40 AM
1997F-350's Avatar
1997F-350
why not???
maybe some messed up uvc's, gaskets or outer pugs.
maybe even a loose nut on the ipr.
Alaskan Ford
Apr 22, 2009 06:20 PM
tazaxx
Sep 25, 2007 03:19 PM
cruzer23
Feb 16, 2007 10:36 PM
smits03ps
Dec 15, 2003 05:39 PM
