Forged crank
Old Mar 28, 2006 | 01:16 AM
Bdox's Avatar
Bdox
Forged crank
Does anyone know if forged cranks for the 4.9 use the same flywheel and harmonic balancer as the cast cranks?
Old Mar 29, 2006 | 01:17 AM
Col Flashman's Avatar
Col Flashman
Yes, yes they do & state this from experience as I've a '66 Steele Crank in my 300 I-6.
Why would you believe otherwise?
Old Mar 29, 2006 | 02:00 AM
Bdox's Avatar
Bdox
I wasn't harboring any particular belief, I was just curious. Wondering if there is any difference in harmonics the two types generate. I guess that if Ford used the same harmonic balancer and flywheel assemblies they must be the same or very similar.
Old Mar 29, 2006 | 08:34 AM
SR_Crewchief's Avatar
SR_Crewchief
The trick is finding one. They were only produced from 65-80 and only appeared in "light duty" trucks sporaticly and not by design.
Casting numbers (that I've found) are C6TE-G and C5TE-F.
ClatonK
Jun 20, 2005 11:57 PM
Powergod
Apr 5, 2005 02:10 AM
46 Y-block
Apr 23, 2004 09:40 AM
Nitro
Mar 5, 2002 06:57 AM
