Major Problem...
Old Mar 26, 2006 | 02:44 PM
EricHB's Avatar
EricHB
Angry Major Problem...
I have a 04 6.0 thats been sitting still for about five months because I've been away on business. I have a banks power tuner installed in the truck.
I drove the truck today and the turbo sounds different. It has a much higher pitch and isn't as loud as it used to be. There's also a major loss of power and the turbo boost gauge goes all the way to 50 psi (tapped out) when I get on the gas. Also, when the tranny shifts, the truck makes that blow-off sound but it's slower than usual. It's also blowing off alot more than usual.
I have the Banks tuner turned off right now. Dont want it to screw anything else up. Any ideas on waht might be wrong? Please help...
Old Mar 26, 2006 | 03:09 PM
Maxium4x4's Avatar
Maxium4x4
I think I covered that question already in your last post. Does your truck over boost without the Banks unit? You might have an issue with the VGT control valve. Kind of hard to tell arm chairing from this distance.
Old Mar 26, 2006 | 11:38 PM
EricHB's Avatar
EricHB
i turned the banks kit off, and it's still over boosting. im taking it to the dealer tuesday.
Old Mar 27, 2006 | 07:16 AM
gp42gpw's Avatar
gp42gpw
I talked to the tech when I was getting my recall done and he told me they had a few of the township trucks that had bad turbo's because they rusted up from sitting. Not sure what the fix is besides a replacement but something to look at maybe some high temp lube will get it working correctly.
Good luck
Glen
05 F-350 4x4 Reg Cab PSD 6Spd.
Old Mar 27, 2006 | 10:30 AM
EricHB's Avatar
EricHB
Thanks GP. I'll mention that to the tech.
Old Mar 27, 2006 | 10:57 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Don't forget to remove the Banks before taking it to dealer.....
Old Mar 27, 2006 | 12:10 PM
big inch's Avatar
big inch
Originally Posted by EricHB
I have a 04 6.0 thats been sitting still for about five months because I've been away on business. I have a banks power tuner installed in the truck....
The turbo vanes are probably stuck. The only fix I know of is to replace the turbo.
lp92chateau
British Columbia
Nov 19, 2006 02:02 PM
hdman6
Jul 22, 2006 04:09 PM
MudBugn
Mar 30, 2006 11:35 AM
Readytorockyou
Feb 27, 2006 10:47 PM
FTE Ken
Site Announcements
Jan 18, 2006 10:41 PM
