Offroad & 4x4
Tcase linkage bolt size???
Old Mar 25, 2006 | 10:27 PM
kc7smo's Avatar
kc7smo
Greetings,
I was just wondering if someone could tell me what size(diameter and length) the bolt is that holds the transfer case shifter onto the tranny?
1988 F-150 c6 and BW1345
I tried a 1/2, it holds, but works its way out after a few days.
Thanks!
Old Mar 25, 2006 | 11:33 PM
fishmanndotcom's Avatar
fishmanndotcom
the bolt on my C6 that was used as the pivot point for my shifter setup was 1 1/8" bolt and it was something like 4-5 inches long.
-cutts-
Old Mar 26, 2006 | 11:35 AM
kc7smo's Avatar
kc7smo
Wow, that's too big for my setup. If the 1/2 x 2.5" bolt isn't the right one, I was wondering if it is a metric size, if anyone knows? What I have works, if I wan't to keep tightening it up every few days so the shifter doesn't fall off.
Anyone know if this is a part available from the dealer? Guess I'll call tomorrow and find out.
Thanks though!
Old Mar 26, 2006 | 09:04 PM
MBBFord's Avatar
MBBFord
Go to junkyard and you could get one in 5-10 minutes for $5 if not free.
My bolt is pretty big to, but mine is a 79.
Old Mar 26, 2006 | 09:19 PM
kc7smo's Avatar
kc7smo
I'll have to check the yards, I kinda thought they would all have either been taken or dropped into the mud by someone who didn't need it.
I'll look though.
Thanks
Old Mar 26, 2006 | 09:38 PM
MBBFord's Avatar
MBBFord
You need it to shift the 4wd. I haven't seen a truck w/out one, not even parted out junk trucks.
Old Mar 26, 2006 | 10:09 PM
fishmanndotcom
you are talking about the bolt that holds the shifter on and is what the shifter pivots on right?
if so you need that bolt, it is kind of weird, has a long fat neck with a 1 1/8" bolt head and then has 1/2" threads i beleive. i have a couple extras if you are looking for one
here's a crappy pic but you get the idea http://www.manestruckparts.com/store...roduct_745.jpg
try this... take the same bolt you have and put it through your shifter, then run 2 nuts on the bolt leaving just enough room for the shifter to pivot but not tight on it. then tighten the nuts together, this will create a plce for the bolt to stop but you wont be tightening down on your shifter. everytime you shift it wont turn the bolt.
-cutts-
Old Mar 27, 2006 | 08:29 AM
kc7smo's Avatar
kc7smo
Fishmann, that's exactly what I need. I'd love to take one of your spares off your hands, PM me about it...
Thanks much!!
RUSTY50F1
1978 - 1996 Big Bronco
Oct 17, 2014 12:22 PM
wreckinball
20
Jan 8, 2011 12:09 PM
Monster-4
Modular V10 (6.8l)
Aug 7, 2008 06:05 PM
72shadetree
Jan 10, 2008 10:47 AM
72RangerXLT
Sep 18, 2002 10:35 PM
