Modular V10 (6.8l)
Collector bolt size?
Old Aug 7, 2008 | 01:45 PM
Monster-4's Avatar
Monster-4
Anyone know the size of the bolts that hold the exhaust manifold to the y-pipe collector?
Old Aug 7, 2008 | 03:53 PM
dkf's Avatar
dkf
M10x1.5 You'll need a new gasket if you take it apart because it sticks fast.
Old Aug 7, 2008 | 04:07 PM
Monster-4's Avatar
Monster-4
Thanks for the info dkf!
Old Aug 7, 2008 | 04:42 PM
chissler's Avatar
chissler
There is no gasket there (machine fit). I used 3/8 coarse 3" stainless bolts when I put my headers on.
But the studs in the manifolds are 10X1.5. as are the three studs that attach the y-pipe to the main pipe just in front of the cat, there is a 3-bolt gasket there.
Old Aug 7, 2008 | 05:30 PM
dkf's Avatar
dkf
Had a brain fart, thanks for pointing it out chissler. The 3 bolt flange where the cat pipe and the y-pipe connect have the gasket. The 2-bolt ball and socket connector on the manifolds has no gasket however you can use a thin film of Ultra Copper RTV on it to help prevent leaks. Both the 3 bolt flange studs and the studs at the ball/socket are M10x1.5.
Old Aug 7, 2008 | 06:05 PM
chissler's Avatar
chissler
I know i had to read it a few times to make sure I wasnt about to make an *** out of myself......
NS70250
Sep 16, 2016 08:59 AM
williameub
Nov 11, 2015 01:48 PM
ToMang07
71
Jun 8, 2015 03:36 PM
blue oval owner
Jun 4, 2015 05:54 PM
morepower16
Exhaust Systems
Oct 13, 2004 03:33 PM
