Something Wrong Here?
Old Mar 26, 2006 | 01:16 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
its a done deal. $54 and some change.
anyone want to buy a DRV++? works great
Old Mar 26, 2006 | 04:34 PM
Kwikkordead's Avatar
Kwikkordead
Strokin_it if your EGT is that low and the you're trying that hard, it's a fuel supply problem.
That could be loss of fuel pressure, loss of HPOP pressure and the resulting weak injection event, or both.
I had the same symptoms as you describe. Low EGT's. Turned out I had a clogged fuel pump inlet. It supplied great pressure at idle low RPM and light load driving, but anything over 2500 RPM was flat and weak.
It could also be a simple as a clogged fuel filter.
Old Mar 26, 2006 | 05:24 PM
PowerstrokeJunkie
im going up to my girlfriend's house tonight, so i can try again and check the EGT's.
Old Mar 26, 2006 | 08:55 PM
PowerstrokeJunkie
kwik, i checked the situation out THREE times tonight. two of them were on flat ground, from 45-75mph in drive. i let off at 75 just for "safety". those times the EGT only got to 1050* or so. on the way home from her house i took a different route with a long uphill straightaway. i slowed on the bridge to about 20, and then just rolled into it. i let off at 80 or so, and then i was still locked in D. glanced over and saw the pyro at 1200*. so no, i dont think fuel's the problem.
Old Mar 27, 2006 | 02:50 AM
Kwikkordead
Ok, Kris then I think you are simply defueling like the others are saying.
Imondi
15
Sep 16, 2008 03:28 PM
miller_feed
16
Aug 16, 2008 10:17 AM
PowerstrokeJunkie
40
Jul 29, 2007 11:54 AM
f350rebel
Jul 1, 2007 08:49 PM
