Spacers between the bed and frame? ('53)
Old Mar 24, 2006 | 05:59 PM
xfordman's Avatar
xfordman
I set the bed back on the frame and it seems to set a little low in the rear. Is there suspost to be spacers there?
_______________
XFM....
Old Mar 24, 2006 | 07:25 PM
53fatfndr's Avatar
53fatfndr
I don't believe so. But, there wouldn't be anything wrong with adding any if it doesn't look right.
Old Mar 24, 2006 | 07:52 PM
grncoup's Avatar
grncoup
there are supposed to be some pads between the frame and bed, but they aren't very thick.
Old Mar 24, 2006 | 08:32 PM
LEckart's Avatar
LEckart
There are some "bed to frame" insulators made of rubber, I think a couple different thicknesses. Check the MidFifty or another vendor's catalog.
Old Mar 25, 2006 | 12:25 AM
B/B ford's Avatar
B/B ford
Clean & Classy
Did you c-notch your frame? Its possible that the frame got warped down from the heat during welding.
Old Mar 25, 2006 | 06:05 AM
merc546's Avatar
merc546
They sell a bed to frame insulator kit like LEckart said. The kit contains several spacers that seem to be between a 1/16 to approx 1/8 thick. In fact I used the thin at the front and the thick at the rear to get mine to look somewhat level.
Chuck
Old Mar 25, 2006 | 07:15 AM
brewster1's Avatar
brewster1
I cut my insulators out of the sidewall of a tire. Worked fine. Miine was low on one side at the rear and I added spacers until I got it level.
Jim
Old Mar 25, 2006 | 07:49 AM
xfordman's Avatar
xfordman
Thanks for all your reply's, I guess I need to put a running board on and see if it lines up with the bed and rear fender, then stand back and see how it looks. I guess I'm to nit-picky, I've been told " this is an old truck, not the space shuttle"...LOL
Old Mar 25, 2006 | 05:11 PM
imlowr2's Avatar
imlowr2
When I removed mine, it looked like several pieces of bicycle inner tube cut up and stacked between the frame. I removed it and cut some square pieces of neoprene rubber, punched a hole for the bolt and put that in. I believe the rubber is more for reducing friction and squeeks, rather than leveling the bed.
Old Mar 27, 2006 | 09:54 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I mad a set of insulators for my truck bed from some 3/16" reinforced rubber. I found a rubber dealer in the yellow pages, told them what i needed. They had a huge selection of thicknesses and compositions and gave me the small piece I needed (it was a drop from a different sale) I bought the guys in the shop cokes adn went on my way. I cut the rubber to size with a utility knife and punched the holes in it with a gasket punch.
Bobby
Old Mar 27, 2006 | 11:22 AM
theGman's Avatar
theGman
I keep a few Mack new truck mud flaps around for various rubberisms like this.
The flaps have at least 2 different thicknesses on each one.
Paul
Old Mar 27, 2006 | 12:35 PM
Jag Red 54's Avatar
Jag Red 54
Brewster is right. You add rubber until it sits level to the frame. Also, the cross members in the middle have a beveled notch on them that needs to be situated correctly to the frame. The high sides of the notchs face toward the axle as I remember. Harbor Freight has a degree tool on sale for $2.99. It would help determine if the bed is the same tilt as the frame. Jag
swampthang
Jun 29, 2014 09:47 AM
truckin42
Dec 18, 2013 05:18 PM
Roger T. Pipe
Oct 21, 2013 07:49 PM
fyreduck1921
Aug 6, 2013 07:08 PM
62 squire
1961 - 1963 F100 Unibody
Apr 17, 2011 05:19 PM
